Re: 2nd Build (first) - Saturn CNC 2'x4'
Originally Posted by
ger21
My opinion is that everything should be in the cabinet, and the cabinet should be well sealed with well filtered intake air coming in. If you mount the VFD outside of the cabinet, it will fill with dust eventually.
You'll never see a VFD mounted outside of the cabinet on an industrial router.
I would always use shielded cable for the spindle, limit and home switches.
So noted, thanks Gerry!
CNCMAN172
Agree with Ger21, you should always use shielded wire, if you are using a VFD and Spindle they generate a huge amount of EMI and your will have nothing but trouble with false e-stops and everything else if you fail to use shielded cables and proper grounding.
Russ
Don't want any false e-stops or false signals of any kind. Thanks, Russ!
- - - Updated - - -
The spindle mount just arrived. I'm now 5 minutes closer to finishing - LOL! That's all it took to mount this, so while I can't run without it I figure I've only gained 5 minutes.
David
Romans 3:23
Etsy shop opened 12/1/17 - CurlyWoodShop
