603,894 active members*
3,989 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > 3 axis cnc machining question
Results 1 to 4 of 4
    Jan 2023
    Question 3 axis cnc machining question
    Hello,
    I'm a beginner in cnc, and my question is, how to get a smooth and polished surface on a complex curved model form of wood or metal,
    on a 3 axis cnc machine?
    Does a 3 axis cnc machine does the job? Or do I need a 4 or 5 axis cnc machine to do it?
    And do I need a specific software to do it also?
    Regards
    Sam
    Jan 2013
    474
    Quote Originally Posted by Samyueru View Post
    Hello,
    Regards
    Sam
    Definitely 5 axis work. 3/4 axis would not have the ability to cut 3D shapes smoothly.
    4 axis tends to be indexer type of work. It really does depend on the component complexity.
    Jul 2018
    6841
    Re: 3 axis cnc machining question
    Hi Sam - We'd need to see what you mean by "complex curved" and a polished surface is usually achieved after machining. There are machines that can produced "polished" surfaces but they are some millions of $$$ to buy. And since you mentioned metal the game gets even harder... So publish what you are trying to do and the members can better help. Peter
    Apr 2004
    5951
    Like Pete says, "polished" implies another operation after the machining is done. But your surfaces will be smoother if the finishing tool passes are closer together. So the strategy you choose for a given area has to take its steepness into account. If you're cutting a surface that's approaching the vertical, parallel cuts that looked fine on shallower areas become further apart vertically, leaving a "stairstep" appearance. A "waterline"strategy will work better in that case, since you can specify a vertical distance between each cut. If you're looking for a way to cut the whole thing evenly, then a 5+ axis machine works best, since the tool can be kept tangent to the surface however it's laid out.
    Andrew Werby
    Website
  1. CNC Fixturing question for 2-sided machining
    By RacerJoe in forum Work Fixtures / Hold-Down Solutions
    Last Post: 01-15-2018, 02:25 AM
  2. Replies: 0
    Last Post: 10-24-2013, 04:49 PM
  3. Newbie question about multi-axis machining
    By neeboy in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-02-2013, 10:51 PM
  4. 5 Axis CNC Machining
    By tariqfayyaz in forum News Announcements
    Last Post: 11-06-2011, 12:48 PM
