603,943 active members*
3,190 visitors online*
    Mar 2012
    6
    3 Axis CNC Mill Software for PC - Checking Axis Movement
    I purchased a cnc mill package some 10 years ago and just now setting it up. (finally retired)
    It came with Mach2 software. Didn't know it would be "DEMO" version. This may be the reason
    I can't test the machine xyz movements, or for that matter, anything else.
    Is there any software I can try to obtain my goal ? Try and Buy or Freeware or ? My experience,
    years ago, 3 axis mills with FANUC controls.
    I think the Mach2 interface screens are much too crammed. Is there software with clean, basic
    control out there ?
    Would a "Tablet PC" (touch screen and Windows) be a better choice for control ?
    Thanks for your time.
    Apr 2004
    5951
    Re: 3 Axis CNC Mill Software for PC - Checking Axis Movement
    That software is fairly obsolete by now. You should download the latest "lockdown" version of Mach3 from Newfangled Solutions » CNC Software Home of Mach3 . The demo version will still run 500 lines for free, so you can test out your system before throwing more money at it. You might like the newer screen-sets better too.
    And no, a tablet isn't likely to work at all. Get an old (but not 10 years old) desktop computer running something from XP to Windows 7, 32-bit version, that has a parallel port capable of operating in EPP mode.
    Andrew Werby
    Website
    Mar 2012
    6
    Quote Originally Posted by awerby View Post
    Thank you for your insight and advice. I have several pc towers that fit your description.
    Rick
  1. uncommanded A axis movement when doing 4 axis work.
    By Tristar500 in forum Mach Mill
    Last Post: 09-12-2014, 02:47 AM
  2. Grinding and unexpected axis movement if rapiding 2 axis
    By DarkSabre in forum Taig Mills / Lathes
    Last Post: 03-26-2010, 05:37 AM
  3. Putting together Taig mill, question about Z axis movement
    By DE001 in forum Taig Mills / Lathes
    Last Post: 03-13-2010, 09:18 PM
  4. Replies: 14
    Last Post: 04-30-2009, 01:17 PM
