603,960 active members*
2,198 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > 3 projects of CNC Router 3Axis, 4 Axis and 5 Axis
Results 1 to 12 of 12
    Oct 2007
    17
    Talking 3 projects of CNC Router 3Axis, 4 Axis and 5 Axis
    Oct 2007
    17
    Talking
    proress
    Oct 2007
    17
    Cool
    progress
    Sep 2003
    1113
    I do like the "Bridge Approach" (dual rails straddling the z axis) on your Y axis (its a favorite of mine too). If I could suggest:
    consider rotating the z axis 90 degrees (about the z- vertical) - you might have an easier time changing bits in it.
    That assumes you'll have access to the table along the X axis - which is most common. Any way you look at it - you'll be giving up working footprint - but make changing bits a bit easier.
    :cheers: Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Apr 2006
    3498
    good drawing...can u share ur design
    Oct 2007
    17
    Quote Originally Posted by Khalid View Post
    I used studio max 8 3ds
    Oct 2007
    17
    Quote Originally Posted by High Seas View Post
    :cheers: Jim
    Excellent suggestion, but as I make that?
    Apr 2005
    11
    LuthierX,
    you are a crazy guy!
    Manda bala garoto!!
    Sep 2003
    1113
    LuthierX
    Kinda like this:
    http://www.cnczone.com/gallery/showp...00/ppuser/1938
    Best of luck!
    :cheers: Jim
    Oct 2007
    17
    Smile
    LuthierX
    Kinda like this:
    Best of luck!
    :cheers: Jim
    is this?
    Sep 2003
    1113
    Sorry for a very late response - but yes! Nice dagream too. You can see readily how your layout will prevent torsion (bending) as a result of the router/spindle weight being asymetricly mounted on the Y axis. You do have to make sure the Y axis members are rigid enough to prevent bending in the Z axis though.
    Good Luck., and
    :cheers: Jim
    Apr 2006
    3498
    I am also a experience work on 3D studio max.. I learn it when we have 3d max ver 4 and now its ver9
  1. 3 projects of CNC Router 3Axis, 4 Axis and 5 Axis
    By LuthierX in forum Uncategorised MetalWorking Machines
    Last Post: 02-25-2008, 04:12 PM
  2. DIY 3axis router milling machine
    By pinemartin in forum CNC Wood Router Project Log
    Last Post: 05-23-2007, 06:50 PM
  3. 4th axis on my router
    By ronnieman in forum CNC Wood Router Project Log
    Last Post: 03-19-2007, 12:35 AM
  4. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  5. Projects For 3-axis Mini-mill
    By moose in forum Community Club House
    Last Post: 03-24-2004, 06:57 PM
