588,528 active members*
6,985 visitors online*
Results 1 to 6 of 6
    Jul 2005
    82
    3 Shaft Adapters/Couplers
    Hello,
    I need 3 shaft couplers that go from 1/2" to 3/4".
    Bore A: 3/4"
    Bore B: 1/2"
    Outter diameter: 1 1/2"
    Length: 2 1/2"
    Material: 6061 Aluminum
    The depth of each bore should be equal, meaning 1 1/4" for each one, nothing special needs to happen in the middle. I plan to drill and tape the set screws for this, so no need to worry about that.
    Tolerances should be pretty tight, although i'm not Nasa or anything. Obviously this should be done on a lathe, i tried doing this myself with machineable-bore couplers from mcmaster, and using a drill press, but they are off a tiny bit and make the machine do horrible things, so I need to them to be made well.
    Or if someone knows where to buy these, I can't for the life of me find any supplier that has these, most only step 1/8" of an inch, not a 1/4".
    thanks,
    Ross
    Apr 2008
    .125 OR .250 STEP
    IF YOU WANT A .250 STEP YOU HAVE TO GO FROM 1.0 INCH TO .500 INCH BORE , THAT WILL GIVE YOU .250 OF LIP AROUND THE BORE .. ITS ALL DIVIDED IN HALF , RADIAL DIM.
    Jul 2005
    82
    I did not mean step as in how much to step your lathe, i just meant that the diameter bore difference is generally at most an eighth of an inch (at mcmaster and others).
    It states very clearly that I want Bore A to be 3/4" and Bore B to be 1/2", there should be no other interpretation
    Jan 2006
    2985
    Mcmaster part # 6208K243
    Bore A: 3/4"
    Bore B: 1/2"
    Outter diameter: 1 3/4"
    Length: 2 3/4"
    Material: Aluminum
    $52.04 each
    part 6507K3 will also do 1/2 to 3/4
    Both of these are flexible couplings, it looks like you need one bored out if you have to have a rigid coupling.
    Regards
    Matt
    Jul 2007
    39
    Hello, P M has been sent
    Thanks Brian
    Brian's Machine & Powdercoat
    Jul 2005
    82
    Thank you everybody for the response, I have filled this order.
    Thanks for taking you time to response/send a message,
    Ross
  1. Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft
    By DonW in forum DIY CNC Router Table Machines
    Last Post: 03-17-2008, 09:58 PM
  2. Home made shaft couplers
    By EL34 in forum DIY CNC Router Table Machines
    Last Post: 09-25-2007, 09:47 AM
  3. shaft couplers
    By dgalaxy in forum Benchtop Machines
    Last Post: 02-01-2006, 06:18 PM
  4. Good Shaft couplers
    By klick0 in forum MetalWork Discussion
    Last Post: 01-01-2006, 03:23 PM
  5. shaft couplers do i need
    By craftech in forum DIY CNC Router Table Machines
    Last Post: 11-29-2004, 04:26 PM
