603,311 active members*
2,152 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill > 3015 Fiber Laser Cutting Machine 2000W Stock in Chicago Warehouse
Results 1 to 1 of 1
    We have a 3015 Fiber Laser Cutting Machine 2000W Stock in
    Chicago Warehouse
    We can setup and run the machine before you pick up or ship.
    We can offer you training too
    We will support you if you have any question in our USA office
    Call 847-984-0882 for any question
    https://www.automationtechnologiesin...sheetcutte2000
    Working Area: 59" x 118 " (1500 mm x 3000 mm)
    Control System: CypCut E, BoChu FSCUT2000E controller
    Industrial Computer
    Max Laser Generator 2000W
    Laser Head: RayTools BM110
    Driving System: Delta 750W Servo Motors for X, Y, 400W for Z
    Dimension Tolerance: 0.05mm
    Positioning Tolerance: 0.02mm
    High Quality Rack and Pinion Guide Rails
    Italy MOTOVARIO Gear Reducer
    Cooling System: Water chiller Hanli 60HZ 2KW
    Transformer 220v 3ph - 380 3ph 40kva
    Stabilizer ( Or Regulator) 380VAC 50kva
    Air-Assist: Oxygen or Nitrogen
    Nitrogen proportional valve and Oxygen proportional valve
    Machine Power Supply: Three Phase 220 V
    Power Consumption: 15-20 kW
    Gross Weight: 9850 lbs
    Cutting nozzle: 30 pcs, Protective lens: 25pcs, Ceramic ring : 5 pcs
    Dedicated USA technical support from qualified technicians and engineers
    Attached Thumbnails Attached Thumbnails 2KWlasermachinea.jpg   2KWlasermachineb.jpg   2KWlasermachinec.jpg   2KWlasermachine.jpg
  1. 3015 FIBER LASER METAL SHEET CUTTER 2000W
    By automationtechinc in forum Fiber Laser Cutting Topics
    Last Post: 03-23-2024, 06:50 PM
  2. Replies: 0
    Last Post: 09-02-2014, 08:28 AM
  3. Replies: 2
    Last Post: 08-30-2014, 07:36 AM
  4. Newest update of 2000W fiber laser cutting machine
    By gnapple in forum Vertical Mill, Lathe Project Log
    Last Post: 08-26-2014, 08:36 AM
