586,069 active members*
3,554 visitors online*
    Nov 2011
    261
    3015 stone processing machine
    Attachment 443014
    This machine can meet the processing requirements of cutting, edging, polishing and engraving of different materials.
    The machine automatically changes the tool during the whole process without manual intervention, which reduces the labor cost and improves the production efficiency for the enterprise.
    The bed is welded seamlessly with thick-walled steel pipes to ensure higher machining accuracy.
    The working table is made of steel plate, which has the advantages of anti-rust, good load bearing performance and long service life.
    Jan 2021
    Re: 3015 stone processing machine
    A plasma polishing machine is way more effective. And takes way less space. Of course, it's a bit more expensive, but it's generally considered a better solution and more and more industries are buying it. In addition, it has other advantages you can check here plasma polishing stainless steel https://pvdcoaters.com/product/category/epp
  1. Replies: 1
    Last Post: 11-09-2015, 02:36 PM
  2. Stone engraving machine: The spring of stone applications
    By Tongxing in forum Education - Teachers and Students Hangout
    Last Post: 09-10-2015, 10:12 AM
  3. Need Owners Manual for Amada FO 3015 Laser machine!!
    By LaserSpyder in forum Machinery Manuals / Brochures
    Last Post: 05-29-2014, 04:52 PM
