Greetings -
I have a 2010 3016 with 18i Fanuc controls. I am in the process of fitting up an air speeder, and noticed that M19 registers to a different position that the one for a tool change, which in the macros is M190. As locating the speeder is critical for for the torque bar/air feed - can anyone explain the difference? Is there any way to have them be the same?
Also, I tried to index the spindle by degrees (rotate the spindle and end up X degrees from 0.) Some controllers do this but I can't figure out how to make this work on the Fanuc 18i.
I appreciate any help! Thanks - Jon
