588,585 active members*
13,803 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
Page 7 of 7 567
Results 121 to 128 of 128
  1. #121
    Nov 2007
    361
    Re: 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
    So does the a1 terminal play a part or do I just wire it 1 nc to the bob and the other nc to the relay/on off switch
  2. #122
    Mar 2007
    2083
    Hi Michael
    on the KJD17 switch terminal A1 needs to be connected to terminal 24 via one of the E-stop N/C contacts
    the second E-stop N/C is connected between the BOB E-stop input ( usually pin 10) and the input common
    Attachment 437602
    Attachment 437604
    when the E-stop switch is pushed the KJD17 switch will switch off killing the supply to the spindle and stepper driver power supply
    the BOB will signal an E-stop to the PC
    John
    PS
    it looks like I will have to find the original diagrams used to produce the spindle wiring diagram as the diagran here on cnczone has a reduced resolution in post 103
    note - the KJD17 switch shown is the UK version with a 240V and you need the USA version switch with a 120V coil !
  3. #123
    Nov 2007
    361
    john the 1st post to the drawing looks like it started on post # 24 but it is missing the no volt on off switch
  4. #124
    Nov 2007
    361
    John I was wondering if you know anything about a spindle sensor for a mini lathe to be able to thread ? I have just bought a mini lathe and I am converting it to cnc and I need to get something for threading and I was thinking could I use this same setup that I have for the mill for the new mini lathe just with 2 axis?
  5. #125
    Nov 2007
    361
    Quote Originally Posted by john-100 View Post
    Hi Michael
    Attachment 437602
    Attachment 437604
    John
    PS
    John I have the kjd17 switch wired with the a1 wire and the 24 terminal has the live coming from the main plug from the wall and the estop does nothing with it is pressed what am i doing wrong ? There is nothing plugged into the 23 terminal should there be ??
  6. #126
    Mar 2007
    2083
    Hi Michael
    with the mains supply connected to terminals 13 & 23
    when you press the green button terminal 14 is internaly connected to one end of the coil
    the free end of the coil is terminal A1 that needs connecting to terminal 24 to latch the switch ON
    by connecting A1 to 24 via one of the E-stop switch N/C contacts
    the switch will open when the E-stop switch is open
    Attachment 437820
    the E-switches second set of N/C terminals can be connected to the BOB's input pin 10 & common to signal an E-stop to mach 3
    is this any easier to follow ?
    John
  7. #127
    Nov 2007
    361
    Hi Michael
    Attachment 437820
    John
    John,
    Yes much easier to follow I am stuck trying at the e stop ....I ran 24 and a1 to the estop but now I have to run the 24 through to the 1xhcel so do I have 2 wires leaving the e stop
  8. #128
    Mar 2007
    2083
    yes you have 2 wires connected to terminal 24 -
    the connection to A1 via the E-stop and power to the spindle controller and DC power supplies
    As it might not be easy to crimp 2 wires in the quick fit connector you push onto terminal 24
    you will find it easier to connect 1 wire between the switch terminal 24 and the Live input to your 5V or 36V power supplies
    and the wire to the E-stop switch
    how was the power originally distributed ?
    power looped from one power supply to the next and the spindle control
    or are there terminal blocks distributing the power ?
    John
Page 7 of 7 567
  1. 8 spindle rotary Cnc router making craket bat
    By omnisales6 in forum Videos
    Last Post: 06-29-2016, 04:02 AM
  2. Replies: 3
    Last Post: 12-20-2012, 07:09 PM
  3. Replies: 9
    Last Post: 07-05-2012, 08:57 AM
  4. Router Won't Turn On At Beginning of Program
    By notselrach in forum DNC Problems and Solutions
    Last Post: 02-06-2009, 10:08 PM
  5. G-Code to turn on and off router, non-spindle
    By Sam A in forum G-Code Programing
    Last Post: 10-25-2008, 02:02 AM
