325 Coolant Pump
I am having a problem with my coolant pump, it starts out pumping fine & continually dies off. I pulled the pump & there's 2 rubber wasers just floating on the shaft, coolant sprays out of the top of the pump cavity & I assume that these rubber washers are there to contain that, but I don't understand how. There's a hole in the shaft, like there's supossed to be a roll pin, but it's a little too high to contain the rubber tight enough to do anything? Anybody know about these pumps?
Also, Are they really 3phase 220volt pumps??
www.turtleracingproducts.com
