587,518 active members*
2,993 visitors online*
    Sep 2008
    Unhappy 35 Watt Laser Engraver
    Hi! I'm new to the forum and hoping someone has a solution. I have a 35 Watt Vytek Laser engraving machine that they no longer make. (Tile Bandit)
    As the laser is engraving, my table is raising by itself! Not sure if the buttons are sticking or what? Anyone have this experience before?
    I have jobs pending and am a bit frustrated!
    Thanks in advance if anyone has any ideas...
    Beth
    Sep 2008
    117
    Quote Originally Posted by Etches View Post
    Hi Beth,
    Can't help with the problem, but the brute force solution could be disabling the raising mechanism. If it is raised and lowered by an electric motor, then insert a switch that cuts the power to the motor when you have it at the height you need.
    If it is raised by air, then put in a small ball valve to do similar.
    My guess is it is raised by an air cylinder and the solenoid valve that controls the "up" part of up/down is leaking air through to the cylinder.
    Dave
  1. Synrad 50 watt laser
    By KTP in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-11-2011, 09:38 AM
  2. Marking Stainless using CO2 laser 60 Watt
    By Huahahahahaha in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-06-2010, 02:10 AM
  3. Artcut JSM 40 watt laser
    By ccroyscuba in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-17-2009, 11:40 PM
  4. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2007, 08:39 PM
  5. 60 watt engraver- opinons?
    By replicapro in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-15-2007, 01:41 AM
