Can you get a fanuc post which outputs as canned cycles rather than g1/2/3s?
Sent from my SM-A300FU using Tapatalk
the default fanuc post will have basic canned cycles already built in. If your trying to do something that isn't specifically built into the post it will translate it to G01,G02,G03 and G00 moves.
If you have the time and interest in editing your post yourself the most useful guide I have found is
https://forums.autodesk.com/t5/hsm-p...s/td-p/6371381
