588,182 active members*
4,215 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > 3D CAD 2010 to dxf to G-code issue
    Sep 2012
    Good morning folks. I have been struggling with an issue to create a G-code from an AutoCAD desktop 3D model of a 1911 pistal grip saved as a DXF file. I am new at this and have a CNC 6040 3 axis routing machine. I have tried to load the DXF file as an import but the file is not recognized by the Mach3 software. I have downloaded a lisp comand for my AutoiCAD program which is supposed to generate a G-code within Autocad but It doesnt recongnized some 3D elements. I am having a dificult time getting the generater to read a "mesh" 3D form to generate a G-code. I hope this doesnt sound all too confusing... the bottom line is I cant seem to get a G-code out of an AutoCAD 3D form.... has anyone had a similiar problem and has found a way to generate smoothly a G-code from an AutoCAD 3D form? I would apreciate some assitance with this mater.
    Mar 2003
    35538
    If it's a solid model, export it as an .stl and import the .stl into a 3D CAM program. Very few CAM programs can read a .dxf of a 3D solid.
    You'll need a CAM program like MeshCAM or Cut3D, or CamBam.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2012
    Thanks Gerry, I'll try that out.... best regards, Tony
  1. Issue with G Code
    By nova24 in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-14-2012, 11:19 AM
  2. G code issue
    By bipe in forum Mastercam
    Last Post: 12-14-2010, 01:01 AM
  3. AutoCAD & Inventor 2010 Shared Network Issue
    By RoboFutbol in forum Autodesk
    Last Post: 07-21-2010, 04:02 PM
  4. G-code issue on G81 / G99
    By tikka308 in forum BobCad-Cam
    Last Post: 03-30-2008, 09:01 PM
  5. Solid cam issue, filleted corners in g code
    By ozturbo in forum Solidworks
    Last Post: 09-19-2006, 11:15 PM
