Heres a guitar I modeled in rhino, it needed to be thicker then an electrical guitar, but the shape is the same as an electrical guitar. But it wouldn’t be hard at all to make the exact model of an electrical guitar in rhino. One thing to take into consideration with rhino when doing fillets is the begin process of building your curves, once I built my curves I’ve changed the degree and tolerance and then rebuild them before I extrude them. With out doing this you might have some trouble using fillet surface command; also you can try to use the fillet edge command as well. I'm still learning rhino, but you need any help with rhino let me know.
Best regards,
Mark
wireframe
