We can scan 3D objects for you. Our laser scanning technology is some of the most reliable on the market today. We don't just scan objects. We make watertight .STL files that you can mill on your CNC machine without fear of holes. Holes can ruin a CNC spindle in a heartbeat.
We have been using our laser scanner technology for 3 years now and can now produce "scan to mill" files that are accurate to within 1/32 of an inch. On top of that, we have the ability to add "level of detail" using Virtual 3D Carving Technology.
Want to watch us scan your object? We can invite you to an Internet based collaboration platform, where you can sit in your office, and watch our scanner in action. All you need is an Internet connection and some free software that installs in minutes.
If you are a woodworker using CNC in your shop, you know how hard it is to generate 3D Carving details for reproduction and replication. When you do generate them, often there are times that you have to hand-carve anyway. Even with the best software, it is often very hard to replicate an object with ornate carving details.
If you are an architect, not only can we recreate 3D architectual millwork for your company, we can mill it for you as well on one of our 3 CNC machines.
In addition to scanning your object, we can use our CAD software to recreate geometric profiles for moldings, corbels, columns and many other objects, and then, apply the .STL Laser Scan detail to the part. Upon completion of this process, we can add the needed containment fields and recommend cutting strategies that will minimize per piece CNC time and maximize production for your machines.
New Wave Woodworking is at the forefront of Laser Scanning and CNC Technology. We don't build the lasers and the CNC machines, we push them to new heights! We invite you to visit camheads.org to see a small portion of our work. Our new website will be launching shortly. In the meantime, check out our latest "Scan to Mill" job.
Basic scanning services start at $100.00 and up.
The link below will take you to my User Profile at Camheads.
(You may need to register to view photos)
http://www.camheads.org/member.php?u=190
