587,172 active members*
2,789 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > 3D Milling Surface Finish Problem
Results 1 to 16 of 16
    Jul 2005
    8
    I'm doing some 3D surfacing on 1018 steel and am getting a bad surface finish. See attached picture. I understand there will be step over marks but I'm not happy with the pitting.
    I'm doing a rough cut with a 1/2" end mill, .4" step over, .01" surface offset.
    The finish cut is with a 1/2" 2 flute carbide ball mill, 15.4 ipm, 2567 rpm.
    Any recommendations? Should I lower the step over on the rough cut?
    May 2004
    105
    jkeyser14
    What's the stepover you have the ball end mill set for?
    -John
    http://www.engineeringhobbyist.com
    Aug 2005
    413
    What type of holder is the finish mill in, setscrew or collet? I would try making the finish pass all one direction instead of zigzag. I usually get a torn finish like that when 3-d milling when the tool is not climb milling. You get a nice line one direction but then on the way back it goes to hell.
    Also what is the stepover fo the finish mill? Is it solid carbide? For the .010" skin you have left you must remember that when a ball mill cuts only that deep the actual cutting diameter is very small. There for the RPM can go quite a bit higher.
    Out of curiosity, what is the part you are cutting? It almost looks like a anvil horn.
    JP
    Jul 2005
    8
    Thanks for the tips, I'll try a one direction cut next time.
    The step over on the finish is .0275" (.0005 scallop height)
    The tool is being held in a collet holder and is solid carbide.
    The part is a die for flaring steel tubing on a press.
    I used the speeds and feeds recommended by the tool manufacturer for a DOC of .1" (.2xD) and .25 WOC (.5xD).
    Is there a good formula or guideline to adjust the speed and feed for a lighter cut?
    Mar 2006
    2712
    TurboME.
    You might try contacting A.S. Thomas Inc. I worked with them on milling gummy stainless steel turbine blades. They had designed and patented an indexable carbide insert tool that had geometry built in to act almost like a wiper. 63-32 Rms finish & no tears or rips in the surface. They are in MA. www.asthomas.com
    DZASTR
    Aug 2004
    2849
    Seems to me that you're trying to cut a taper and the result that you're getting seems acceptable.....just think about what the profile of the end mill looks like......you need to look at another scheme for cutting the taper....I would think a lathe would give you a much better finish.
    Sep 2005
    59
    The problem with ball nose cutters is twofold.
    The cutting edge geometry at the bottom of ball does not give much room for swarf clearance and more importantly the speed of rotation is virtually zero at the bottom of ball. In effect you`re pushing the material rather than cutting it.
    Wherever possible its far better to either tip the head over or clamp the job at an angle to cut further up the flute of the ball nose.
    Either way you`ll have to datum the job through use of a tooling ball mounted on the job. But this extra setup time far outweighs trying to hand finish the part.
    Mar 2006
    2712
    Joey, The cutter mentioned in #5 eliminates that problem, it is not a ball end mill. Also, you might Google "sturz milling" and "P-6". It might give you a different idea.
    DZASTR
    Dec 2006
    8
    What machine and software are you using?
    The two 1/2 cutters your using will do just fine, you just need to change the step over, step down, rpm, and feed. You may also need to look at how your getting the chip out of the cut, but from the look of your part that shouldn't be a big problem.
    Nov 2006
    303
    Doesn't look that bad. Most 3d stuff will require some "hand finishing" to blend away the step overs if your looking to get smooth surface. Hand finishing is an "art" that is under appreciated in most shops.
    Dec 2006
    8
    Quote Originally Posted by todd71 View Post
    Wrong answer!! 3D can be cut to require NO hand finishing.
    It all depends on the CAM software, cutter used, and machine. The required RMS will also affect the ability to finish the part at the machine, but I have successfully cut to 6 RMS on my V56 Makino and I cut to 10 RMS on a regular basis. Handwork is an “art” but also a necessary evil, we will never fully get rid of it but the need is for it is reducing every year.
    I don’t mean to bash anyone, but just because it isn’t done in your shop doesn’t mean it can’t be done.
    Aug 2006
    15
    I agree with jason's previous post,, we polish and hand fit NOTHING when making our plastic injection molds, unless of course they need a diamond finish on a show surface. The accuracy and finish off of todays high speed milling machines is remarkable. Looking at the picture the first thing that comes to mind is that the conventional move your making is killing your finish,, I would only climb mill even if you have more rapid and lifts, tool life will be much longer,, finish will be much greater and size will be more accurate.. also more rpm's. This is a picture I personally programmed and cut from start to finish on a high speed 5 axis machine,, it is a core for an engine cover mold which required NO hand fitting of the shutoffs and NO polishing.
    Nov 2006
    303
    One hand say "Wrong" and then validate it in the same post? "Handwork is an “art” but also a necessary evil, we will never fully get rid of it but the need is for it is reducing every year." I agree it needs to be reduced but if you don't have the resources for the latest and greatest you have little choice. Thats was my point. Pretty much what you said.
    Apr 2003
    3578
    Blowmebigtime nice looking tool.I have to ask what cad-cam system and type of path he is using.
    Also the .027 step over is to big for that curvercher surface.
    he is better off with the .01 step as the tangency of the tool is changing due to the curve of the surface. also how is he holding it?
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Aug 2006
    15
    One other thing I might mention that alot of people might not use is, MQL (minimal quantity lubricant) I use Acculube and blast that thru my oil mist on absolutely everything from roughing to finishing, using that the tool is lubricated so well that I can get away with some conventional cutting passes removing minimal stock without that tearing or having a torn surface which is so easy to get in material such as P-20.
    Aug 2005
    235
    You could try using a corner radius endmill instead. Higher RPM and mist coolant will be an asset.
