603,870 active members*
3,102 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > 3D milling toolpath generating unwanted paths
    Oct 2009
    6
    Dear members of the forum, I will appreciate your advise on the following issue.
    I am trying to carve the face of a cylindrical body (half a cylinder)
    The attached JPG is a 3D representation of the toolpath
    As you can see, at the end of every pass:
    1. The tool raises in a vertical motion to the height set as the clearance level
    2. Descends again in a vertical path
    3. Moves on to the next 3D pass
    These vertical motions to the clearance level and back are an unwanted overhead.
    I will be grateful if you could show me which configuration controls this behavior and how it can be altered.
    Additional relevant information:
    - The technology I am using is semi finish (linear)
    - The geometry was set by selecting the target face
    - I am using FANUC
    Thank you
    Ariel
    Jul 2011
    71
    Are you using a 3D Milling toolpath or HSS? ...and which version of SolidCAM, 2010? 2011? (some of the options have moved in 2011)
    assuming 2011:
    If you are using a 3D milling toolpath, then try changing the 'Stay on surface within gap of:' values on the Link page. Increasing the value to something bigger than your step over will force the tool to stay down.
    If you are using HSS, then take a look at the links tab on the links page and modify the links between slices options.
    Hope that helps!
    Apr 2011
    Used circular pocket ( start ftom INSIDE)
  1. Generating safer paths?
    By nghiaho12 in forum CamBam
    Last Post: 03-10-2009, 02:53 PM
  2. Generating paths (Gcode) from Illustrator CS2
    By bigal in forum Uncategorised CAM Discussion
    Last Post: 06-14-2007, 10:05 PM
  3. Toolpath Group posting generating several NC Files
    By mattford1 in forum Mastercam
    Last Post: 05-31-2007, 01:26 AM
  4. 4-5 axis milling toolpath
    By aldebaran07 in forum Mastercam
    Last Post: 05-21-2007, 02:42 PM
  5. generating tool paths from solids
    By jderou in forum BobCad-Cam
    Last Post: 10-26-2005, 12:04 AM
