603,963 active members*
2,558 visitors online*
Results 1 to 6 of 6
    Jul 2022
    24
    3d probe issues
    Hi All, another stumbling issue, I dumped the touch plate Idea and went with a 3d probe thinking I would simplify things ?
    Issue I'm having is not enough voltage at the C25 input pin to make Mach4 happy ....
    here is the schematic for the probe:
    Resistance between Vcc and Signal measures 5K
    Vcc connected to 5V
    Sig connected to P2-10
    Grd to Grd
    Sig (not connected to C25 has 4.9V
    Sig Connected has 2.07V
    Light on C25 is dim
    Has anyone come across this and find a solution? Or a suggestion to try ?
    Again TY in advance for any input
    Randy
    Jul 2022
    24
    Re: 3d probe issues
    Was playing with it today not connected to ess
    If I:
    -supply 11 volts to the VCC
    - added a 4.7k resistor between Sig and GRD I have 5V between Sig and Grd
    So in theory, this needs a VCC of 12V ???
    As the Ess is supposed to have a 4.7K onboard?
    Nov 2013
    5413
    Re: 3d probe issues
    I have replied to this post on the ESS forum.
    Craig
    Jul 2022
    24
    Re: 3d probe issues
    Quote Originally Posted by joeavaerage View Post
    Craig
    Hi, Yes just noticed, still confused on how to make this work, specially if I look at:
    Jul 2022
    24
    Re: 3d probe issues
    Looks like there asking for 10k of resistance on the Sig circuit? which I would get if i wired in a 4.7k in series.??
    Jul 2022
    24
    Re: 3d probe issues
    Posting the solution so it is available to others if they come across this issue.
    Added a 3K resistor between 5V Vcc and Signal wire.
    All working as required.
    Tkx to all for the help.
    randy
