587,189 active members*
3,175 visitors online*
Results 1 to 10 of 10
    Oct 2010
    62
    3d profiling in Solidcam
    I am familiar with 2.5d profiling. However I have a part in which I need to cut a 3d profile. Please see the image attached which shows the part I am struggling with. It would be helpful if someone could tell me the kind of operation that I should be using so that I can play around with it.
    Jack
    Feb 2008
    21
    send me model than i will sort out for you
    Oct 2010
    62
    I cannot attach the files to my posts on this forum. However if it helps I can send the files by email. Alternatively, if you can post me in the direction of the right machining operation to use then that would be appreciated.
    I can cut the stock using 2.5d profiling. However the tool then crashes with the stock and the fixtures. It seems that I need to tell Solidcam to follow a profile and cut down to a surface.
    Feb 2013
    49
    i think it would be better to re-design the fixture for better machining posibility :-)
    Feb 2013
    49
    i think it would be better to re-design the fixture for better machining possibility :-)
    Feb 2013
    49
    the stock could potentially make 2 parts instead of 1 :-)
    Oct 2012
    60
    JackWilliam, I would recommend one of the high speed machining operations or at a minimum 3D Milling. This should allow it to be roughed out and then finished. Normally the way I would make these is to rough it down flat to the highest surface and then rough it in steps to it's profile shape. You'll have to make sure the end mill doesn't hit the screw and that it is small enough to go between them. After that, get a ball mill and finish it with a stepover that gives you the scallop you want. Not sure how you're going to make those square edges. Good luck!
    Mar 2011
    24
    3D engraving is what I would do if changing the fixture is not an option. Create a "target" and choose the profile, done.
    Nov 2007
    330
    Could possibly use 3D contour
    Jul 2011
    71
    HSS is awesome for any 3D profile or surface. To follow a single edge, use projection, or morph btwn 2 edges on a surface. Hard to say for sure without the model.
  1. z profiling help
    By turbothis in forum Dolphin CAD/CAM
    Last Post: 12-20-2009, 04:03 PM
  2. Z-profiling
    By dlenardu in forum Milltronics
    Last Post: 12-12-2009, 03:48 AM
  3. profiling
    By chaz6966 in forum BobCad-Cam
    Last Post: 02-22-2009, 01:15 AM
  4. profiling
    By camtd in forum GibbsCAM
    Last Post: 02-25-2008, 03:17 AM
  5. Profiling
    By dneisler in forum SprutCAM
    Last Post: 09-29-2006, 11:45 AM
