603,982 active members*
2,753 visitors online*
Results 1 to 4 of 4
    Sep 2010
    Question 4 Axis TB6560 to Mach3 Config ? ?
    I have a TB6560 4 axis (but only using 3 axis) and configuring with Mach3. I have three stepper motors out of a Canon Laser Copier FH6-1571 2.2volts and 2.0 amps. I am totally confused about how to set my jumper pins on the board (should I run it at 100%, 75%, 50% etc.) and which micro step setting to run. And in Mach3 . . I find that very confusing as well. I built this little machine myself because I just want to get my feet wet with CNC. I am using 5/16" all-thread directly driven from the steppers and the TPI (thread per inch) is 18.
    I hope I can find some help. If not then
    Is there an Idiot proof board that is user friendly with gobs of simple instructions?
    Jan 2010
    2141
    The blue TB6560 boards that I have seen on eBay come with factory-installed resistors to set the maximum motor winding current at either 1.0 amp or 3.0 amps. Is your board one of the blue ones? The DIP switch settings of 50%, 75%, etc. are based on the resistor setting representing 100%.
    If you have one of the boards that is wired for 3 amps maximum, and you want to run 2 amps through the stepper winding, there is no 66% DIP switch setting, so you would probably want to try it out at the 50% switch setting. The 75% setting would not be very far off from the desired value, but since it exceeds the rated current you may not want to try it.
    If you later wish to increase the current, you should be able to replace the resistor value with the proper value to give you your desired motor current with the DIP switches set to the 100% value.
    (I hope that makes some sense.)
    As far as the microstep setting, I would start off with either full steps or half steps, just to get the motors moving, and then decide on whether and how to do microstepping. FYI, some people have reported that the 1/8-step and 1/16-step DIP switch settings on some of the boards are reversed.
    You can configure Mach3 to correspond to whichever microstepping setting you choose.
    Sep 2010
    TB6560 Help
    Thanks Doorknob for the help. I'll run it at 50% but now I have to find out the specific settings for the ports and pins settings in Mach 3.
    Jan 2010
    2141
    Is it the blue TB6560 driver board?
    If so, try this for the pin numbers:
    X step 16
    X direction 1
    X enable 4
    Y step 14
    Y direction 7
    Y enable 17
    Z step 3
    Z direction 6
    Z enable 5
    A step 9
    A direction 8
    A enable 5
  1. Mach3 setup with TB6560
    By rwijbenga in forum Mach Software (ArtSoft software)
    Last Post: 03-02-2014, 06:00 PM
  2. 4 Axis TB6560 pin setup in MACH3???
    By proph3t in forum Stepper Motors / Drives
    Last Post: 12-18-2012, 07:20 PM
  3. config pin in mach3 for co2 laser
    By tessen in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-12-2008, 08:34 PM
  4. Steps per/mach3 config
    By bp092 in forum Gecko Drives
    Last Post: 02-22-2008, 07:49 PM
  5. Config Mach3
    By rex2 in forum Machines running Mach Software
    Last Post: 01-26-2008, 10:52 PM
