603,316 active members*
2,693 visitors online*
Results 1 to 7 of 7
    Feb 2010
    3450
    Talking $400-Master Horizontal MILL 3 axis BIG.
    Mill, Horizontal , Master , 3 Axis , Conventional
    Model: FT5-HFCS
    Serial Number 881
    Head Stock : Model –LC5HF6-DD500 , HP: 5 , Est.
    Travels: X = 60 in. Y =12 in. Z = 5 in
    Mill has no controls and is being sold “as is”. Footstep: 113 in. x 39 in. x 60 in.
    1st off Where is the table on this sucker!? $400 bucks sounds like a steal if i could fix her up and get it running! maybe even convert it over to cnc. but i still dont understand where the damn table is! Thoughts? Opinions? Auction ends 6PM GMT-8, 9/9/2010.. As in today. Shoot me your thoughts. thanks!
    Oct 2006
    976
    Hello,
    To me it looks like this is just the horizontal moving head that probably attached to a large work table.
    Regards,
    Wes
    Dec 2003
    24260
    Master Machine Tools show up as still active company.
    Master Machine Tools Inc
    600 Scott Boulevard
    Hutchinson, ks 67505-8714
    Phone: (620) 663-4451
    They appear to specialize in burnishing machines, which this could be a type of.
    I would suspect it either works in conjunction with a bed mill or other separate mounted work piece.
    A quick call to them may bring some light on it?
    Motors and parts maybe worth $400.00, but the cost of converting to any kind of CNC may not be worth it unless you can use it in its original intended purpose.
    Al.
    Albert E.
    Feb 2010
    3450
    I'll give them a quick call. To bad it doesn't have the table attached then it would be a pretty cool.
    Jul 2007
    1602
    It doesn't really need a table all the movement is provided by the unit. The installation provides the surface for part holding. Park it somewhere and bolt the stuff to the floor. Or drive a truck up next to it do some machining on the truck then drive away.
    Chiron mills work much the same way though they are vertical mills. It is a pretty interesting setup since the weight of the part being machined doesn't affect the machine dynamics.
    bob
    Oct 2005
    1237
    Um. Calm down. Put your bid card down and walk away from the auction. Do you <i>need</i> this? Can you use this? Does your shop have room for it? Sure, its a great deal, but it might prove folly to buy it just because it is cheap.
    Feb 2010
    3450
    Quote Originally Posted by MrWild View Post
    Auction ended.
    Ya i didn't bid on it. Do i need it, no. I have my hands tied up at the moment with 3 mills as it is and hopefully a lathe this fall too haha..
  1. B axis for horizontal mill OM
    By nabil_elbadri in forum Fanuc
    Last Post: 12-09-2016, 08:38 AM
  2. HS1 horizontal mill with auxillary axis alarm
    By teal854t in forum Haas Mills
    Last Post: 04-18-2009, 06:47 PM
  3. Disabling A-axis, horizontal mill
    Last Post: 03-24-2009, 12:56 AM
  4. OKK horizontal cnc mill HMA460
    By bum1033 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-21-2008, 02:18 AM
  5. Haas HS-2RP Horizontal mill
    By ITG in forum Haas Mills
    Last Post: 01-21-2008, 08:31 PM
