I have a mori seiki SL250BSMC lathe. I tried using a live tool for the first time. It worked just fine with the manual controls available. (no programed movement was used). Recalling the events as follows. I brought the RPM up to about 2000 and felt confident things were working fine. Got interrupted in my work and left the machine. Turned off the spindle. Came back and tried rotating the turret position. It did not move. The error code was "411 servo alarm: 5 axis excess err". Not sure what I did wrong that may have effected the problem. I realized that I did not move control back to the main spindle before I tried rotating the turret. Not sure that is related. I then removed the tool from the turret. Restarted the machine. The turret moves just fine (the live tool is still removed). I then remounted the tool in the turret and have the same problem. Can anyone tell me what trouble shooting I could perform? Are there parameters that need to be reset?
Thanks.
