Re: 414 Servo Alarm
Originally Posted by
Jman1823
Hello All,
I have a 1991 Nakamura TW-30 with a fanuc OT-C brain.
It is throwing the 414 servo Alarm X axis detect err
as well as 434 servo alarm 3 axis detect err.
It is almost always on except once in a while it will clear but if i try and engage the C spindle it will trip in right away.
checked dgn 720 and its 0001000 as well as 722 with the same code as 720.
I dont have the manual to see what those codes are.
any help would be great.
Jason
A Fanuc 414 servo alarm is generated by the CNC when it detects that an amplifier has a high current alarm 8, 9, or A. To determine the exact cause, you must go through the process of elimination. The high current alarm may be caused by the servo drives, amplifiers, modules, motor and/or cables.
In some instances, this alarm may indicate a short to ground. The short is causing too much current to flow through the power module inside the amplifier and will eventually cause it to break.
