603,959 active members*
1,843 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Techno CNC > 4896 issues... where to start... (Long)?
Page 3 of 3 123
Results 41 to 41 of 41
  1. #41
    May 2005
    387
    Quote Originally Posted by Ed Lang View Post
    I have no idea about the chip in the PCI card. I have the slow servo machine. The controller, again, I don't know but expect I would since the machine was ordered new with that option.
    Can you show me a picture of what I need to look at to know for sure?
    Ed,
    I have attached the Techno Document they sent me, that explains how to add the 4th axis AMP and PCI Card Chip.
    Pages 3,4 and 5 show how to add the 4th axis Amp.
    Page 5 shows what Jumpers to change.
    Page 6 shows where the 4th axis PCI Chip goes on you PCI card in you computer. If you have four in a row already, you are good to go.
    Page 7 talks about hooking up the connectors from your 4th axis servo, to the control board. All you need to do, is follow the colored wire sequence on on the other 3 axis' and you are good to go. The encoder connection goes on the open connector next to the other three encoder cables.
    The rest of the article is regarding software settings, etc. Not a lot of meat there, but covers the basics.
    Now, this is for an Upgrade to 4th axis. If you already have the AMP and PCI Chip, they you can skip to the section that shows how to connect the cables.
    Here is a YouTube video of my version of the 4th axis. Some modifications have been made since then (moving the Home sensor to the back for one) and the full housing has been removed.
    [nomedia="http://www.youtube.com/watch?v=295Phu8GnjE&feature=channel"]YouTube- 4th Axis production model. Makes same test part twice as fast![/nomedia]
    Let me know if you need anything else.
    D
    Attached Files Attached Files
Page 3 of 3 123
  1. Techno LC 4896
    By mechcanoer in forum Techno CNC
    Last Post: 05-18-2012, 09:43 PM
  2. LC 4896 starts automagicaly
    By Pplug in forum Techno CNC
    Last Post: 04-28-2010, 07:06 PM
  3. wanted dyi plans for heavy 4896
    By Shapegenerator in forum DIY CNC Router Table Machines
    Last Post: 04-21-2010, 12:52 AM
  4. LC 4896 Accuracy Problem
    By ian12 in forum Techno CNC
    Last Post: 01-16-2010, 05:40 PM
  5. Replies: 4
    Last Post: 01-06-2009, 05:20 PM
