603,794 active members*
4,368 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > 49" x 97" MechMate Build in Houston Texas, USA (detailed log)
Results 1 to 19 of 19
    Nov 2007
    109
    Let me first introduce myself - I am David and I live in Houston Texas (actually near the Woodlands), in the US. I am a fulltime software engineer for a large chemical company. In my spare time, I build mostly art projects - art cars and sculptures in metal. In the fall of 2007, I finished my new 1,300 sq/ft workshop that now allowed me to have enough space to pursue CNC. I spent tons of time on cnczone.com looking at all the options for a plasma/router combo table. I came along the plans for the MechMate but I knew that I would have a long road to go down with just the CAD/CAM/Mach 3 and general terminology of CNC. So, I saved off the MechMate plans and decided that I would build a smaller MDF based CNC machine and see how well that worked and if I could master the necessary skills. Well, I did build the smaller CNC machine and faired pretty well (see attached). I was amazed at what I could do with such a basic machine.
    I tried to think ahead and purchase MechMate items that could be transferred over - the PMDX, the Gecko's, Mach3, etc (see attached). Well the time has come to build the MechMate. I started like I think most people do - printing out all the plans and pouring over them until I felt I had a pretty good grasp on how everything went together (I highly recommend printing them on 11"x17" paper in landscape). Next was to assemble a bill of materials. There were a few attempts at a BOM but they were a bit short on detail so I decided to create a highly detailed BOM (see attached) with every washer, bolt, nut, motor, wire, etc - everything. That took about 30 hours of researching, reviewing it against the plans and researching vendors. I currently have ordered about 4,000$ and expect the total (excluding software, Gecko's, computer, etc) for the table (including motors, sensors) to come in at about 4,500$ to 5,000$. I will be releasing the complete BOM once I complete my machine and verify that everything listed is complete and exact.
    Continued in next post...
    Attached Thumbnails Attached Thumbnails mechmate-bom-screenshot%20%28Small%29.JPG   P4270346%20%28Small%29.JPG   P4270349%20%28Small%29.JPG   P4270350%20%28Small%29.JPG
    Nov 2007
    109
    Ordering Parts...Steel...
    I started out by ordering as many of the parts as I could. I personally expect that the research and ordering of parts is as much as 25% of the total build time - we'll see. I am trying to stay as close to the plans as possible but I've decided to deviate from the plans in the following areas:
    Legs - Instead of channel, I am using 2"x2" box tube
    Cross Bearers - I will be bolting instead of welding due to weight issues (and I have to move in 5 years)
    Rails - I will be using ground angle, though it's dimensions will differ from the plans (not Gerald approved)
    Gantry Tube - I will likely be welding the Y rails to the gantry tube instead of bolting as Gerald did in his orginal MechMate
    I will be building with the following options:
    Optional X-Axis Chains
    Optional Proximity Sensors (18mm instead of 12mm)
    Geared motors with 30 tooth pinion
    Milled/Ground Angle for rails
    My first purchase was steel. This seems to be were the most variability occurs - steel is a local purchase and varies in price and avaiaiblity on a vendor by vendor basis. There are a number of steel vendors in Houston - most of them cater to companies but one is more of a "wal-mart" of steel and sells in single stick quanities without any minimum and are even open on Saturday. Of course they are a bit more expensive but they usually have what you want and it's easy to get. SSS Steel is my steel vendor (www.sss-steel.com). They also have a great reference of common US steel sizes here: http://www.sss-steel.com/front/frReference.asp . Here are some photos of my steel order and my special trailer that I use to bring home full 20' sticks of steel:
    Attached Thumbnails Attached Thumbnails P4220321%20%28Small%29.JPG   P4220322%20%28Small%29.JPG   P4240327%20%28Small%29.JPG   P4240328%20%28Small%29.JPG
    Nov 2007
    109
    Ordering...Misc Parts...
    Here are photos of my other parts. I'm still short the rack, motors and paint but everything else is here. I ordered my laser cut "full options" kit (see below) from jbmclain (Joe) in Alabama for $420 (including shipping), including non-v groove bearings with the geared motor option. Highly recommend Joe if he is still doing group buys on parts.
    I ordered nearly all my bolts, nuts and washers from www.boltdepot.com. I ordered everything except for the carriage bolts and nuts/bolts for the skate in stainless steel insted of zinc finish. It was only about 90$ for all the nuts and bolts (see below). I highly recommend them - I will have each of the part numbers from them (in stainless) in the BOM. They ship quick, the price is good, you can purchase quanities as small as 1 and they package EACH type of bolt/nut/washer in a seperate bag with the description and part number - which the BOM has a cross reference back to the specific page the parts are used on.
    I ordered most of the misc parts like the cable management, springs, gears, etc from McMaster-Carr. They ship quick, the quality is always the best and the website is super easy to use - the downside is you pay for what you get. Most of the stuff is brand name - the gears are Boston Gear, the cable chain is Igus and so on. I understand they are not so great when it comes to shipments outside the US, but inside the US - el premo. In the photo (see below) you will notice that I went with adjustable, non-skid feet with insert for the 2x2" legs I've decided to go with.
    The remainder of the items came from Automation Overstock (www.automation-overstock.com), Factorymation (www.factorymation.com), ACE hardware outlet (www.acehardwareoutlet.com), WT Tool (www.wttool.com), Superior Bearing (ww.superiorbearing.com) and K2CNC (www.k2cnc.com) - all shown below.
    Attached Thumbnails Attached Thumbnails P4260335%20%28Small%29.JPG   P4260337%20%28Small%29.JPG   P4270352%20%28Small%29.JPG   P4270355%20%28Small%29.JPG
    Nov 2007
    109
    Cutting cross bearer - 10 10 302 S
    I started with cutting the cross bearers for the support board. I used a 14" chop saw and cut them at the suggested 60 degree angle. I cut one and then used it as a pattern for the remainder of the cuts and it came out pretty good. I did have to re-set the circuit breaker about 50 times but they did cut - total time was about 3 hours. Another 30 minutes or so to clean up the welds. See photos below.
    Attached Thumbnails Attached Thumbnails P4220323%20%28Small%29.JPG   P4220324%20%28Small%29.JPG   P4220325%20%28Small%29.JPG
    Dec 2004
    1316
    Thanks for posting here in the zone. Now that's a lot of heavy steel, you should be able to skip the gym while building this baby.
    Your shop looks nice and roomy. Keep those pics coming.
    Jason
    Nov 2006
    99
    how much was your lazer work and bending??
    Dec 2004
    1316
    Quote Originally Posted by biotech1 View Post
    Post #3
    Nov 2007
    109
    There is no shortcut...
    Well I've given up on welding the Y rails to the gantry tube and now I'm going to bite the bullet and buy the materials needed to properly cut the rails down to the required 1.1" as my steel supplier doesn't sell the 2"x1 1/4"x1/4" angle. The Aluminum and steel rail combo isn't really any cheaper either, even with tools.
    As to the progress... I've drilled all the support bearers. Since I am building a bolt together table, I've drilled 1/2" holes for bolts through the support bearers for attachment to the flange of the main beams. I also stamped identification numbers so if in the future I have to reassemble it, I can get it in the right order. Total time to measure, stamp, punch, drill and then redrill was about 2.5 hours. Here's a tip (I suspect that most people may know..) when measuring out the holes for the outer and inner (on center line of the channel) - find the center and set that on your caliper. Drag the caliper along the outside edge of the channel, scoring a line.
    Attached Thumbnails Attached Thumbnails P4270359%20%28Small%29.JPG   P4270361%20%28Small%29.JPG   P4270362%20%28Small%29.JPG   P4270363%20%28Small%29.JPG
    Nov 2007
    109
    M1 30 224 T - Turned the Hold-Down Idler Stub Shaft
    Today I turned the hold-down idler stub shaft. I'm happy to say that my first ever attempt at turning turned out ok. I used a cheap Harbor Freight 7x10 lathe: http://www.harborfreight.com/cpi/cta...emnumber=93212. I turned mine a little to loose so that the press fit was more like a push fit so I tapped a hole and put on a fender washer to make sure it stayed in place. Photos below.
    Attached Thumbnails Attached Thumbnails P5020364%20%28Small%29.JPG   P5020365%20%28Small%29.JPG
    Nov 2007
    109
    10 10 322 W - Cutting the longitudnal beam
    A few suggestions on cutting the main beam:
    • Don't use a plasma cutter - the arc wanders too much
    • Use an 1/8" metal cutting disk (or maybe 10)
    • Use a right-angle grinder 10amps or better, the 7amp units don't cut it
    • Make sure to have corse grinding wheels
    • Watch your toes and fingers if you are handling the beams by hand
    • Be sure to wear a dust mask
    Attached Thumbnails Attached Thumbnails P5020366%20%28Small%29.JPG   P5030367%20%28Small%29.JPG   P5030370%20%28Small%29.JPG   P5030372%20%28Small%29.JPG
    Nov 2007
    109
    10 10 320 W - Main Beam Closing Plates
    I scrounged around and found some 5 1/2" x 1/4" plate and then trimmed it down to the 3.5" width to close in my beams. Cutting them wasn't a big deal but the welding, and dressing took about an hour to get them really clean. I used a corse grinding wheel for the first run and then a flap disk to smooth it all out. I'll finish the small gaps on the inside later with bondo to obtain a completely smooth finish. Then, when I was done, I used my belt sander to clean off some of the mill scale and rust.
    Attached Thumbnails Attached Thumbnails P5030375%20%28Small%29.JPG   P5030376%20%28Small%29.JPG
    Nov 2007
    109
    10 10 300 W - Attaching the support bearers to the main beam (bolted, not welded)
    I'm bolting on my support bearers to the main beam instead of welding them on. I'm using 1/2" bolts on mine. Shown in the photos is layout of the support bearers, making sure to off set to the proper side. I then clamped on the end cross bearers and measured everything and then laid in the other cross bearers. I then used a transfer punch to mark the main beams from the existing 1/2" holes on the bearers. I then drilled a pilot hole and then the 1/2" holes. Be sure to use plenty of cutting fluid and a corded drill. I then bolted the centers in and then drilled and bolted in the remaining ends.
    I did make one mistake - I measured off the edges of the main beams to line up the edges of the support bearers, where I should have added 1/4" to each side. Nothing major.
    All said and done, it turned out completely square and parrallel.
    Attached Thumbnails Attached Thumbnails P5030377%20%28Small%29.JPG   P5030379%20%28Small%29.JPG   P5030380%20%28Small%29.JPG   P5030381%20%28Small%29.JPG
    Nov 2007
    109
    Finishing up the support structure...
    For the legs I elected to use 2" x 2" x .120" wall tubing since I feel it looks a little more finished and I didn't mind purchasing another type of steel. More importantly, it allows me to use these nifty little nylon inserts from McMaster-Carr (60945K31) and these really nice self leveling feet (6111K373) also from McMaster-Carr.
    For the bracing, I am using 2" OD x .083" wall tubing. For the tube on tube action I am fish mouthing the joints using paper templates.
    To crush the ends where the tube meets the beam and legs, I used my shop vice. Does anyone have suggestions on a better way to form the crushed/oval ends?
    Even though the cross bearers are bolted, I will be welding the side supports back on after I paint it. The tinking is - if I need to disassemble it in the future, I can just cut off the side supports, move it and then re-weld it upon reassembly. The main beams with the legs and supports is liftable my one person, so with the boltable cross bearers, it makes the MechMate "somewhat" portable.
    Attached Thumbnails Attached Thumbnails P5030387%20%28Small%29.JPG   P5030388%20%28Small%29.JPG   P5030389%20%28Small%29.JPG   P5030390%20%28Small%29.JPG
    Nov 2007
    109
    Moving the monster!
    I finished the legs and support structure, so now it's time to flip it over and reassemble it. I propped up one main beam with my workbench and then with the two end cross bearers attached to the other beam, I lifted it upright and then attached it to the other beam. Once both were attached, I "walked" it crab-style into position where I squared it up and then attached all the remaining cross bearers. All done it was within 1/4" square.
    Attached Thumbnails Attached Thumbnails P5040395%20%28Small%29.JPG   P5040397%20%28Small%29.JPG
    Nov 2007
    109
    Y Car Welding
    Other than some confusion about the pictures for the weld-up being for the orginal MechMate and which side the the counter sunk holes go on, it all snapped together perfectly. Here here Gerald!
    I know that Gerald says that clamps aren't neccessary but rather than risk it and to close a few small gaps, I put a few clamps on it.
    When it was all said and done, it turned out completely true and straight.
    Attached Thumbnails Attached Thumbnails P5040401%20%28Small%29.JPG   P5040404%20%28Small%29.JPG   P5040405%20%28Small%29.JPG   P5040406%20%28Small%29.JPG
    Nov 2007
    109
    Update....
    I'm sorry I didn't finish my posts but I have completed my MechMate. In the process, I have posted a very detailed BOM for the MechMate here:
    http://www.mechmate.com/forums/showthread.php?t=814
    Link to the current MechMate BOM in Microsoft Excel (2003 format):
    http://www.dmoore.com/MechMate/bom.xls
    Link to the current MechMate BOM in HTML format:
    http://www.dmoore.com/MechMate/bom.mht
  17. #17
    May 2006
    122
    That BOM is awesome
    You've done a huge amount of work documenting the requirements. Thanks and well done!
    When I'm ready to build, I need to look carefully at your solution.
  18. #18
    Apr 2007
    1955
    Hi, Thanks for posting this - nice work.. Did you happen to post any final pictures of the unit or video anywhere ?
  19. #19
    Nov 2007
    109
    Quote Originally Posted by harryn View Post
    I don't have any photos of the completed, painted MechMate posted yet but I do have video of it prior. They are posted here:
    http://www.cnczone.com/forums/showpo...3&postcount=62
  1. Introducing the "full-size" MechMate router
    By Gerald_D in forum DIY CNC Router Table Machines
    Last Post: 05-27-2013, 05:42 PM
  2. My "S.H.I.G." router build starts
    By picbits in forum CNC Wood Router Project Log
    Last Post: 05-12-2008, 06:48 PM
  3. First Router Build, Is The Frame "Beefy Enough"
    By jimbooboo in forum DIY CNC Router Table Machines
    Last Post: 04-06-2008, 06:49 PM
  4. G320 "common" or "+5vdc" why do they vary?
    By beezerlm in forum Gecko Drives
    Last Post: 01-12-2008, 11:00 PM
