Originally Posted by
TimKoene
I know, but after I ordered and paid for the hobbycnc kit (which should be enroute as we speak) I hit a solid goldmine at work! I found two 50" new IKO 25mm rails with 2 bearings each, two 50" THKballscrews with end mounts and couplings. One has a 150 oz/in stepper, the other had a whopping big 450 oz/in stepper, both NEMA-34. I also found 4 45 inch 25mm NSK rails with 2 bearing blocks each. Also two 10" THK SR-15 rails, sadly only with 1 bearing each. I am so happy, it cost me nothing at all, they were going to be tossed away!!!!! I saved them.
I do not want to take apart that beautiful THK ballscrew assembly, so I want to use it as it is untill I can afford a gecko upgrade.
Thank you very much for your reply Dave!
