603,379 active members*
3,576 visitors online*
Results 1 to 1 of 1
    Oct 2007
    1072
    4th axis cnc indexer
    4th axis cnc indexer ist video
    used a rockwell lathe as an indexer on the cnc machine , located at the front end of the cnc machine
    https://youtu.be/wlq69qAogSU
    2nd video showing the 4th axis setup
    I added an extra stepper motor to drive the lathe, some some experimenting but it worked
    https://youtu.be/HQ6oosT4TQA
    this was done some time back , in summary a person can turn a leg out faster that the cnc machine
    but the cnc can actually carve out a detailed carving on the turning , a person would need a lot of time to do this
    It was a good experiment for me I did all the research , wiring and mechanical work and got advice form some professionals
    showing carving out a graphic of grapes on a large wood turning or cylinder
    wrapping some art on a large wood turned cylinder
    https://youtu.be/7mZhLV-YPlM
  1. What is needed for 4th axis/indexer
    By kopsik in forum HURCO
    Last Post: 03-25-2024, 08:30 AM
  2. using 4th axis or rotory indexer
    By Gallchobhair in forum BobCad-Cam
    Last Post: 04-24-2014, 10:11 PM
  3. r2e3 indexer or 4th axis
    By dougputt in forum Bridgeport / Hardinge Mills
    Last Post: 05-22-2012, 02:28 AM
  4. 4th Axis CNC Rotary Indexer Table Plans
    By Modular CNC in forum News Announcements
    Last Post: 05-11-2011, 07:55 PM
  5. Making best use of the 4th axis indexer
    By josh591 in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2008, 11:39 PM
