603,320 active members*
3,009 visitors online*
    Mar 2003
    6855
    4th axis controller board?
    Is the 4 axis controller board available yet? Any info that anyone can share would be great.
    Apr 2003
    372
    Paul,
    The controller that you were sent should control a 4th axis, you may only need a stepper or servo driver to use the facility, check on the deskcnc board to see if you have an "A: step and direction, if so all you will need is a device to drive you motor. Let me know and I will try to help you out.
    "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
    Greetings From Down Under
    Dave Drain
    Akela Australia Pty. Ltd.
  1. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-14-2005, 03:08 AM
  2. 3 axis stepper motor controller board - question
    By Yellowbeard in forum Stepper Motors / Drives
    Last Post: 04-07-2005, 04:02 AM
  3. HobbyCNC 3 axis controller board review
    By cncadmin in forum Hobbycnc (Products)
    Last Post: 02-10-2005, 11:43 PM
  4. want to add 4th axis to stepperworld fet3 board
    By gv71 in forum CNC Machine Related Electronics
    Last Post: 05-29-2004, 05:10 PM
