I have my machine cutting at 100 ipm, but when the forth axis moves, it moves at 100 deg/min. I cannot find a way to speed that up, other than manually going through the code and adding a new feed rate to each line.
Please help.
thanks Ray
Please help.
thanks Ray
Try putting a small value, like .001 in the Rotation Radius box (in Settings Alt6) , and check "use radius for feedrate" in the Toolpath Configuration box. .
Thank-you Andrew. It took a bit to figure out exactly where you were talking about, but it is working.
Ray
