603,930 active members*
4,118 visitors online*
IndustryArena Forum > CAM Software > CamWorks > 4th axis Post processing
    Jul 2005
    1652
    Question 4th axis Post processing
    Hello
    any one know if it is possible to change the 4th axis movement from Absolute to Incremental? I have found where to adjust to make XYZ incremental, but have not found where to make A incremental. I am doing some fine profiling on my 4th axis and the part will make about 150 revolutions .. however the 4th axis "A" movement is all absolute so my "A" value is very very high about 50000.. so my code looks like this
    X.0603 A-50672.922
    X.0602 Z.8504 A-50674.578
    X.0601 Z.8506 A-50676.234
    X.06 Z.8509 A-50677.89
    Z.8512 A-50679.545
    Not sure if the machine will have that code .. will be out in the shop today trying to see what it does...
    its a Hass TM-1 with a Haas 4th axis
    Any input is greatly appreciated
    thanks
    Mar 2008
    638
    I had the same issue. It's in the post. You have to get a post from the reseller or modify the post yourself.
    Dec 2010
    126
    Your best bet, if you don't know how to modify posts, is to have your VAR fix the post for you. I had the same problem and it involves editing the .LIB files to recognize "B" values greater than 360 and modify them accordingly. It is not an EASY thing to do if you're unfamiliar with posts, but not all that hard if you're willing to take the time to learn.
  1. "Flip 4th Axis" message during Post Processing
    By kfwittekiend in forum Tormach Personal CNC Mill
    Last Post: 09-30-2012, 04:29 PM
  2. Post processing for iTNC 530 Hermle 5-axis machine
    By Dora in forum Uncategorised MetalWorking Machines
    Last Post: 06-19-2012, 12:42 PM
  3. Post Processing
    By machineitright in forum Dolphin CAD/CAM
    Last Post: 02-06-2012, 11:56 PM
  4. ISO post processing
    By imbalanced_MJR in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-23-2011, 08:05 AM
  5. hole processing on 4th axis
    By rbest27 in forum Surfcam
    Last Post: 03-14-2007, 07:33 AM
