Thanks Joe, wow I guess I didn't expect that effort. That table you have is a hog.
At 9 seconds for 180 degrees I calculate your rpm at 3.33. At 5 rpm the 180 turn would be 6 seconds. Where did you get the rpm data, I looked through all the tormach info and didn't see it stated, what did I miss?
The reason I asked is because on my part, you saw it, I have to machine each side with aprox 8-10 tools, most common to both sides, so the question is what is faster, with a given tool in the spindle machine on one side and then rotate and machine other side before changing tools. Or do all the machining on one side making the tool changes, then rotate and do all the machining on the other side.
Thanks again,
2 questions and a comment:
1. Did you spring for a hat?
2. Are we going to see you next month?
3. I have a deckel that keeps calling your name?
