603,341 active members*
5,602 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    As said, i made some assumptions.
    1) the root diameter.
    2) fixing method.
    The root diameter is the smallest diameter on the actual screw and 10mm lead ballscrews of this size normally have large balls so i would have guessed the root to be about 38mm.
    Any motor will turn this screw with the correct amount of gearing, but you need to look at what speeds you need and also take the cutting forces and inertia into account.
    A machine of this size is on the limit of stepper technology and would perform so much better with a servo motor.
    With this 8.5Nm motor you will only get about 5-6Nm running and to get any good speeds you will need very high voltage driver.
    The 5-6Nm is the maximum you will get before it stalls, but even a 400W AC servo motor with 4:1 gearing will give you about this with the peak being three times this.
    The peak also depends on the driver, so you need to check what the peak current of the drive is.
    Quote Originally Posted by motionindo View Post
    Zapp, I use the web link and I enter Root diameter 40mm, length between bearing 3000mm, fixed on both ends and it comes out to 632rpm, but yours is 400rpm. Did I make a mistake here?
    Btw is 1250 Oz stepper would be enough to handle 40mm diameter ballscrew?
    Thanks in advance!
    Zapp Automation Ltd
    www.slidesandballscrews.com
  2. #22
    Oct 2011
    27
    I'll go with modulus 2 helical gear rack then
Page 2 of 2 12
  1. Roton Ballscrew Lead error figures?
    By davo727 in forum Linear and Rotary Motion
    Last Post: 03-17-2007, 11:19 PM
  2. .250 ballscrew lead vs .200
    Last Post: 03-16-2007, 09:19 PM
  3. lead ballscrew
    By vukboban in forum Mechanical Calculations/Engineering Design
    Last Post: 11-05-2006, 08:33 PM
  4. Using 2.54mm/.100? lead Ballscrew
    By Mr.Nerd in forum Linear and Rotary Motion
    Last Post: 06-29-2006, 08:36 PM
  5. lead or ballscrew length
    By woodrow in forum Linear and Rotary Motion
    Last Post: 04-25-2006, 05:58 AM
