603,914 active members*
2,963 visitors online*
Results 1 to 13 of 13
    Apr 2003
    90
    5-Axis Home made Router
    Any one interested in 5-axis routing on a home made machine might want to take a look at this link
    http://www.rainnea.com/cnc_5axis.htm
    Great programming info and a neat video as well.
    Paul Riedlinger
    Let the chips fall where they may...I'm not going to clean them up!
    Mar 2003
    271
    That looks cool. I had been to his site about a year ago. he had'nt made that new machine that was in the video. That looks good. Id like to get some of that aluminum extrution. I have a catolog coming...
    My little piece of the web!
    http://users.adelphia.net/~wjdupont
    Mar 2003
    106
    That is really nice. But wouldn't the part have to rotate in some way to be considered 5 axis? Seems this one has the standard X, Y, Z and then the rotary head. It's still pretty sweet, though.
    Apr 2003
    1361
    The head rotates in a B axis and a C axis. The part doesn't need to rotate.
    Dan
    Apr 2003
    90
    Consider the movement like your wrist. It moves back and forth and rotates. This addes the two additional axis.
    I have a training tape from Thermwood on 5 axis programming that I need to watch....looks interesting. I bet the figuring of the best tool path is a processing bear!
    Paul Riedlinger
    Jan 2007
    14
    thats cool. that is what i call real enginerring. i have a puma robot
    and was thinging of converting it into a 5 axes cnc routing machine
    what do you think.
    Sep 2004
    218
    Cool I say go for it!
    Since you already seem to know everything that won't work. I am wondering why your even on this site and not getting your robot fine tuned as 5 AXIS CNC already.
    Knock yourself out.
    Jan 2007
    14
    i wood like your reall opinion on this progect
    Jun 2007
    32
    Unhappy
    Quote Originally Posted by paulried View Post
    To bad, there isn't a description of the actual building proces.
    That would have been a great help for the un-educated like myself.
    Aug 2007
    5
    There is a site with plans for a machine similar to that. Its called "doughty drive" he sells both plans as well as the b and c axis spindle mount, and an a axis thing.
    http://www.doughtydrive.com/index.html
    Feb 2009
    2143
    Too bad they are so pricey : ( $750 per axis is what I was quoted...
    Quote Originally Posted by drummerboy17 View Post
    Jul 2009
    15
    Guess he likes you... Quoted $850 per drive unit + $350 for the rotating head for B/C. So B/C = (2x$850 + $350 = $2050). Of course $850 more if you want the A axis. Overall he said it cost about $10K for parts for the whole thing.
    Oct 2003
    155
    Talking Went off the DEEP END!!!
    Got one of the mini-trunnions on order!!! Got most of the electronics purchased. Now to start planning the wireing with the new Geckos and
    cnc4pc boards so I can try some 5-axis stuff! Plan on upgrading my three axis cnc shark.
    Hope all goes well!
  1. New home made MadVac CNC router
    By oneyaker in forum DIY CNC Router Table Machines
    Last Post: 02-05-2011, 12:37 PM
  2. Home made threaded rod
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 07-20-2005, 02:26 AM
  3. Dirction / Step lines!
    By bigal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2005, 08:51 PM
  4. home made CNC wire cutter and router
    By geesville in forum DIY CNC Router Table Machines
    Last Post: 02-06-2004, 03:24 AM
  5. 5 Axis Rotery Head Home Cnc Router
    By mace in forum DIY CNC Router Table Machines
    Last Post: 09-18-2003, 05:29 PM
