Hi there
check out this link
http://www.sescoi.com/us/worknc/func...deo_mach.html#
I have been using this software for around 15 years and it work great for all types of machining + 5 axis machining.
There is only 1 type of 5 axis cnc and thats 5 axis cnc.
When you say 5 axis continuous, your right because all 5 axis can possible moving all at the same time at the same feed.
now 5 axis indexing is really called 3+2 axis, where as you can not move the +2 axis when cutting, the +2 axis is only for positioning the head and or table.
you can get a lot more work done with 5 axis cnc vers 3+2 because of the programming time.
There are some really good 5 axis programming software out there,the programing is almost almost automatic these days.
plan on paying around $15000 to $25000 per seat for these type of 5 axis programming software.
here are 3 top players in cam development
worknc
tebis
powermill
If you buy anything less make sure it has welding rod in the box (you will need it) 8->
and also a machine repair guy. no joke 8->
btw these cam programs have built in error checking so there no need for a 3rd part software cost. ch ching
