603,383 active members*
3,819 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 5 axis indexing, not swarf, multi surface etc.
    Jun 2009
    15
    Smile 5 axis indexing, not swarf, multi surface etc.
    Hello,
    I'm doing a 5 axis indexing toolpath, using MX3, on a vertical mill with a indexer mounted on the right side of the table. When I post the toolpath I get b and c for my 4th and 5th axis, what I want is an A value for my 4th axis and B value for my 5th axis. Don't know if it's in my machine definition, control definition, post or something else. Also, if someone could tell me where in my post I can turn on the lock and unlock for my indexer.
    Thank You,
    rroberto
    :banana:
    Oct 2009
    21
    Try to release the breaks for A and B. If the break is on. A and B will want to index only. If the break is off then A and B will feed together.
    Dec 2008
    3211
    Quote Originally Posted by rroberto View Post
    Your post is not yet configured to your machine, until you do, you will not get any A and B outputs ( just B,C ). This best done with your reseller to set-up and prove out the posted code.
    Just curious, are you sure that you have a 5-axis machine, not a 3-axis with a rotary on the X-axis, if you do, then I'd say you have the wrong post
    Table lock / unlock is usually in Misc Values ( I think MI#9, if your post has it )
  1. 5 axis indexing, not swarf, multi surface etc.
    By rroberto in forum Post Processors for MC
    Last Post: 09-08-2009, 01:57 PM
  2. Replies: 0
    Last Post: 08-05-2009, 08:11 PM
  3. indexing 4th axis
    By 69ss396 in forum Haas Mills
    Last Post: 12-03-2008, 10:06 PM
  4. Swarf Cutting 5 axis
    By Master_CNC in forum MetalWork Discussion
    Last Post: 11-13-2007, 06:20 PM
  5. 4 axis indexing
    By camtd in forum PTC Pro/Manufacture
    Last Post: 05-12-2006, 01:20 PM
