603,810 active members*
2,957 visitors online*
Results 1 to 5 of 5
    Mar 2004
    13
    5 axis Micromill
    The Rainnea gantry router inspired my thinking on this one.
    Sofare I only have some small steppers I've ordered for the project. For the 3 stardard axis I have the following -
    107.8 mN.m Holding torque
    24.5 mN.m pull out torque
    16.7 mN.m Pull in torque
    And for the two rotational axis -
    The holding torque is 78.4mN.m
    pull-out torque 27.6mN.m/200pps
    pull-in torque 26.5mN.m/200pps
    Both motors are 4 phase, 7.5 deg stepping.
    Speed is not an issue for this so I figured they can be geared down for more torque. Also, after taking apart a bipolar motor, I'm fairly confident that can be rewound for a lower resistance, greater torque/speed at the cost of heat.
    I'm still unsure on the size of the spindle motor (wattage and RPM) for say a 1mm endmill?
    Also and comments about the practicality of such a project would be greatly appreciated.
    Feb 2004
    2337
    Welcome frOst, thats a full on post for a first timer here.
    I did a quick search on the Rainnea router you mentioned. It looks cool.
    For those who are wondering about it see here. http://www.rainnea.com/cnc_support.htm
    That looks like a very complicated project to make. Have you made anything like this b4?
    Being outside the square !!!
    Mar 2004
    13
    I've done a far bit of brazing and worked with stepper motors, basic robotics stuff but not a cnc.
    Electronics is no problem as I'm fairly proficient with Pics (turbo cnc have a PIC project already). I'm still undecided on software to take advantage of the 5 axis design.
    For machine design I figured a Gantry type would be the best since i'm building from scratch but have C axis as a rotary table instead of rotating the motor. It would leave more room to accomodate gearing and I'd imagine it would leave a better finish when doing spherical objects.
    Matt
    Mar 2004
    1147
    frost - consider mastercam, gibbs pro, visualmill, or, for an "experimental" approach, try the "cnc toolkit"
    Design & Development
    My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
    Apr 2004
    20
    Besides the mechanical works!!
    Can I use Rhino 3d to design the 3D surface, imported to Mastercam, post to Mach 2. Output to 5 Gecko
    and then 5 Stepper motors to operate the 5 axis mini mill?
    Is it correct concept?? or actually Mach2 could not handle the G-code for 5 axis from Mastercam??
    Maybe I should start to try it!
    Why the price of CNC controller is dramatically different???
  1. CNC Glossary
    By cncadmin in forum Community Club House
    Last Post: 03-09-2008, 09:08 PM
  2. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-14-2005, 03:08 AM
  3. No Encoder Counts On X Axis. Y=OK
    By murphy625 in forum CamSoft Products
    Last Post: 03-09-2005, 03:20 AM
  4. 2 axis to 3 axis conversion
    By drembedded in forum Bridgeport / Hardinge Mills
    Last Post: 10-27-2004, 05:32 PM
  5. My Lathe project; might CNC it one day
    By Stevie in forum Uncategorised MetalWorking Machines
    Last Post: 06-22-2004, 02:27 AM
