587,754 active members*
2,771 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Sep 2003
    47
    5 Axis Rotery Head Home Cnc Router
    Hello all cnc and router gurus
    I am Planning on designing and building a 5 axis router
    1. I need input about servos or stepper motors
    2. Machine controller software package for 5 axis or more
    3. Spindles (porter cable 3 1/4 horsepower possible or What?)
    4. input about custom designed toolchanger (possibly )
    This machines envolpe will be approx. 50."X 30." X20."
    I have pretty much decided on THK rail (ebay) for xy and z axis
    4th and 5th axis will be custom design and built by me and Pro E (stainless steel machined weldments, custum gear driven most likly)
    If I get enough input from everyone I will make pdf engineering drawings (very detailed) of whole project step 1 through 350 Material lists etc...
    To all that would like to be involved and eventually build your own Please start posting.
    The designs will be posted step by step and displayed as we go in this Thread So all can be envovled that want to be in designing !!! (however I will have final say )
    Money i will spend on this project will be approx $3500.
    I get all metals at cost From the machine shop i work for and also have alot of steel tubing i can use for free.
    So materials is pretty much coved What i need for you guys is knowledge of home cnc.
    Expect to see 1st designs in 3 weeks from now
    Mace
    Mar 2003
    2139
    !. I would go servo's and Gecko320 drives
    2. TurboCNC does up to 8 axis, Not sure about Mach 1
    3. That router works great.
    4. Add this later. Get up and going first.
    It would be great to see. I look forwarsd to seeing what will happen!
    Eric
    I wish it wouldn't crash.
    Apr 2003
    98
    Hi
    You may want to take a look here
    http://www.rainnea.com/cnc.htm
    this guy has a homemade 6 axis machine and software for programing it.
    Ray
    Learn from the mistakes of others you can't afford to make them all yourself!
    Sep 2003
    47
    Here is preliminary design of base with thk rail
    Mar 2003
    2139
    Choose "Attach file". make sure your image is in JPG format.
    Eric
    Mar 2003
    2139
    This going to be a moving table or moving gantry design? If moving gantry, you need to think about the leadscrew location and getting a table on top there somehwhere. I put my thk rails on the side, so I had a spot to put the table. If I did it again, I would put the thk rails under the frame for two reasons: to keep them out of the dust, and to equalize the wear so it's not always on the one side of the bearings.
    Have a look:
    Eric
    Aug 2003
    23
    looks good
    im a newb at home cnc. im planing on making a 3+ axis machine in the near future. id love to see your plans, sounds very promising.
    __________________________
    dont take life to serious ....no one gets out alive....
    Sep 2003
    47
    updated
    I will be starting to design rotary late this week
    Mar 2003
    2139
    Nice,
    A couple of comments. If you are using one x axis leadscrew, you need to tie the angle brakets together underneeth, for a place to attach a nut. Even with two screws, tieing it together here will help keep it more rigid.
    The z-axis plate for holding your spindle needs to extend beyond the bottom bearings by the amount of z axis clearance it has. Otherwise, the spindle won't reach the table. I am not saying it needs to be like my machine, but here is a pic of what I mean.
    Not being critical, just pointing out some stuff that I learned the hard way...
    Eric
    Sep 2003
    47
    But dont forget about 4th and 5th axis rotary on the front z plate
    the mechanics and assembly of this device will bring placment of router down I have A vision but not modeled in Proe yet remember this is all preliminery design in proe this can all be ajusted in a matter of minutes.
    So I am not so worried about every aspect like the ball screws until i have all the major components designed and modeled.
    I acually plan on having major changes after major design is done.
    This is really just A design concept.
    mace
    Mar 2003
    2139
    Of course. I am starting to see it now. I will keep watching for updates.
    Eric
    Jun 2003
    2103
    Hi mace. While I may not have very much to input I am very interested in the 5 axis head design since this is something I want to do in the future except I want to build a really small one.
    I am talking something on the table top size that can be picked up and carried by one person.
    Are you thinking of using belts to drive the 4 and 5 or round spur gears?
    turmite
    No greater love can a man have than this, that he give his life for a friend.
    Sep 2003
    47
    Turmite
    I have not decieded on gears or timing belt system yet.
    An engineer that I work with is saying to use belt drive easier cheaper and wont wear out.
    But I am concerned that when making 5 axis cuts 4th and 5th axis would have to much play and slop.
    So any input is helpful!!!!
    Mace
    Mar 2003
    2139
    A belt system will have the least backlash.
    Eric
    Jun 2003
    2103
    My current cnc machine uses belts and there is no backlash that is perceivable {I haven't indicated it} while the motors are entergized. I think the belt system is the way to go if you have the room for it. On the little one I am wanting to build I don't think I will have the room and keep it as compact as I want. On the other hand all I will ever carve on it will be wax, wood and maybe some really soft metals.
    turmite
    Sep 2003
    47
    servos
    I am looking for servos to continuing the design I need help on locating and compatabilitiy with GECKO and size
    I would like to be able to cut 6061 AL. with 1/2 " cutter 1/2" deep with mist
    I am considering going to 96 inches on X axis
    1.What size should i get for extra power?
    2. Do they all have to be the same size ?
    3. Should it be direct or reduced ?
    4. Should and could I make 4th and 5th axis reduced for power and accuracy?
    5.Will mach2 and or turbocnc adjust for 4th and 5th axis reduced
    6. Where can I look at assortment with prices ?
    I am pretty sure that c axis (rotates around z axis ) will have no hard limit switch so that i can spin more that 360 degrees each
    way
    B axis which rotates +90 and -90 will have limit switchesalong with x y z axis .
    So any thoughts are welcome !!!
    oppss this was suppose to go in 5 axis router thread
  17. #17
    Mar 2003
    2139
    I merged them for you.
    1) at least ~1/4 hp is my guess.
    2) No
    3) Reduced usually. Depends on motor voltage and RPM, and powersupply voltage.
    4) You could, and probably should. They generally rotate less that 360 degrees. I don't think you would want direct drive here.
    5) yes
    6) Do a search on ebay for servo or DC motor (if you want to attach seperate encoders).
    Eric
  18. #18
    Mar 2003
    779
    Just a note. You may find that when you power off the servos your z axis will fall with the extra weight on the screw. I have the Porter Cable 3 1/4 router and my z axis just barely holds at 2:1 ratio.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
  19. #19
    Sep 2003
    47
    balsaman is there not a company that sells at resonable prices?
    mace
  20. #20
    Mar 2003
    2139
    For servos and drives try Jeffs place : http://www.homecnc.info/
Page 1 of 2 12
  1. New home made MadVac CNC router
    By oneyaker in forum DIY CNC Router Table Machines
    Last Post: 02-05-2011, 12:37 PM
  2. 3 axis CNC Router with AC/DC Brushless motors (Need help with electronic Design)
    By StressedMech in forum CNC Machine Related Electronics
    Last Post: 05-15-2005, 05:26 PM
  3. purchase or building a home cnc router.
    By s_bedow in forum DIY CNC Router Table Machines
    Last Post: 03-19-2005, 07:22 AM
  4. buscht's cnc router
    By buscht in forum DIY CNC Router Table Machines
    Last Post: 04-13-2004, 05:43 PM
  5. home made CNC wire cutter and router
    By geesville in forum DIY CNC Router Table Machines
    Last Post: 02-06-2004, 03:24 AM
