Well I need to mill out some profiles in acrylic. I tried 3 types of double tape, and 2 types of hot glue to fixture the plastic down. After some limited success, and several exploding pieces of acrylic (think mythbusters exploding cds) I got some pieces made. After fighting with such a simple job I decided I should probably make a vaccum table. I will probably convert a cheap hotdog air compressor once I get going, but I figured I'd play around with a venturi first. So I scanned some of the venturi threads here and got to thinkin how could I do a "quikie".
I started to go thru some of my stuff and realized a mig tip is .25". Hmm too easy I say. I cut up some 3/8 plastic tubing (about .25" id) and stuck the .035 mig tip in there, and clamped it. Then I dug up a .25" pushlock tee, and stuck the mig tip in and hit it with some air. I felt a little pull on the branch, and I got excited (yeh, I need some better interests...). I pulled out my calibration gear (I'm a Jman at instrumentation) and checked the vaccum. I was pulling about 2.5 psi, but I could feel the air from the mig tip was "rough". Then I stuck in a piece of 1/4" tubing and it started pulling over 4 psi, so I say to my self "self, this is pretty cool". I started cutting off the 1/4" tubing untill it seemed to top out at over 5 psi vaccum. Judging from the air compressor run time I guestimate it uses about 3cfm of air at line pressure (95-120psi).
Not bad for 5 minutes, and 5 bucks.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
