603,359 active members*
3,897 visitors online*
Results 1 to 5 of 5
    Apr 2006
    40
    Question 5 volt positive and negative??
    The wiring diagram says + and - but there is no indication on the adapter. Which one is positive and negative? black and black with white stripe??? Does is matter?? I assume it does??
    Thanks,
    Rooney
    Aug 2008
    409
    Black with white strip is positive usually. If you have a Meter you could check it.
    Apr 2006
    40
    Thanks for the reply, Phife.
    All I have is an analog meter.
    Tell me if I'm wrong here.
    Plug the adaptor in. Place one probe inside the end of the plug. Place the other on the sleeve of the plug. The inside or sleeve of the plug, whichever gives me a positive voltage reading with the red probe on it, is the positive.
    Is this the correct procedure??
    Aug 2008
    409
    that is correct.
    Apr 2006
    40
    Thank You, Phife.
  1. Kitamura Mycenter 1 480 volt to 240 volt conversion?
    By mjrockwellus in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2008, 05:14 PM
  2. G53-Z SHIFT AMOUNT NEGATIVE
    By coondog in forum Daewoo/Doosan
    Last Post: 05-17-2008, 04:21 AM
  3. Making a positive mold from a negative mold - how?
    By SRT Mike in forum Moldmaking
    Last Post: 03-29-2007, 10:30 PM
  4. G83 + G72 with negative return plane
    By drewmeister in forum Haas Mills
    Last Post: 02-21-2007, 01:21 AM
