588,478 active members*
5,342 visitors online*
    May 2006
    94
    5 volt power supply connection
    I just received a 5 volt power supply that has identical cut-off wires on each end --no AC plug. Does it matter which end receives the AC plug , and which wire on that plug is hot? If it matters, how do I tell? Thanks!
    Dec 2003
    24221
    Obviously the supply and output connections have to be correct, is this a switching supply or linear regulated or un-regulated? and make or model?
    Al.
    Albert E.
    May 2006
    94
    5 volt power supply
    This is to supply 5 volt power to stepper drivers and BOB for 3 axis system. Its sold by Keling, Taiwanese made, what may have been a name plate literally cut out with probably a utility knife, model 7202C-3, P/N 1333561, but these may be meaningless. (Just Googled the model # -its a power supply for IBM Lexmark printer!) Wonder why he cut off the plug? Maybe it wasn't conventional 110 plug...
    I see when I look more closely which wires are for 110 in, which for 5 volt out. One of the 110 in wires has a stripe on it -that one hot I presume? thanks!
  1. Power supply for 24 volt steppers
    By db113 in forum Stepper Motors / Drives
    Last Post: 04-23-2012, 12:35 PM
  2. Acme electric 24 volt power supply?
    By ged in forum CNC Machine Related Electronics
    Last Post: 12-05-2006, 08:45 PM
  3. 0 - 90+ volt variable DC power supply
    By webbch in forum CNC Machine Related Electronics
    Last Post: 10-06-2005, 01:01 AM
  4. 5 Volt Power Supply Tripping
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 02-28-2005, 04:05 AM
  5. 24 volt dc power supply
    By natchez in forum DIY CNC Router Table Machines
    Last Post: 04-02-2004, 06:31 AM
