588,367 active members*
8,179 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 5 wire Sanyo Denki connection Diagram Needed
Results 1 to 5 of 5
    Jan 2007
    12
    I am a mechanical engg student
    I got a stepper motor of brand Sanyo Denki for our project
    Its got Specifications like
    DC 1.5A .72DEG
    TYPE 103H8582 8044
    Lot No 01817
    Made in Japan
    5 wires I cant find how to get it rotate as i cannot find about 5 wire connections in their website either .Can anybody help me with this?
    Apr 2010
    Quote Originally Posted by Fonfon View Post
    DC 1.5A .72DEG
    TYPE 103H8582 8044
    Lot No 01817
    Made in Japan
    thankyou
    May 2006
    6
    I was checking a 5-wire stepper out yesterday, and according to my resistance readings, it's like a 6-wire, except the 2 center-taps are tied together. I don't know that you can use a normal 4-wire controller with it. My guess is you'll need to use a 6-wire (Unipolar?) controller. Locate the common ground wire (all the other wires will have their lowest resistance reading when compared with the common), attach the common to the center-tap for one of the phases, and jumper it to the center-tap for the other phase. You'll need to mix-n-match the other 4 wires to the terminals to get proper direction. Keep good notes on which wires you hook up where, and wither the step pattern is correct. Hint: use a truth table. Good luck! It should only be a max of about 12 different combinations, but that's only if you have the worst possible luck and don't get it right until the last try!
    Dec 2008
    226
    When you find the common, tie it to a voltage source (use a current meter to dial in the 1.5Amps through one winding and note the voltage) then set the voltage to about a quarter of that to keep the heat down while testing...
    place 4 normally open bush button switches on the four wires, going to ground.
    place a pointer of some kind on the shaft of the motor... alligator clip... paperclip... whatever.
    press the first button, then the second while watching the pointer and then back to the first, then the third, first and fourth... you are looking for the smallest movement... that is the first two A - B ... now press A,B then each of the other two, smallest increment will be C the other D
    now you should be able to press A B C D A B C D and see a smooth progression even while holding a little pressure on the shaft... label the wires and your done. To change the direction of rotation, switch EITHER A & C or B & D
    If you can find them still , a 5804B IC can drive a unipolar 1.5 amp with no other parts for a basic (slower) driver... http://www.datasheetarchive.com/pdf-...DSA-385061.pdf
    Dec 2008
    226
    I have a circuit that uses the phase outputs of the 5804b to drive two current control stepper driver ICs but I cant post the whole thing it because it is from a place I used to work and they sold the intellectual property to someone else a while back, but I could probably draw the basics of the phase hook up if you wanted it, but look at http://pminmo.com/ first
  1. Sanyo Denki Resolver needed urgent!
    By dresda in forum Servo Motors / Drives
    Last Post: 08-13-2014, 06:19 AM
  2. Sanyo Denki Help
    By Gary D in forum Stepper Motors / Drives
    Last Post: 06-30-2012, 06:10 AM
  3. Sanyo Denki PM Driver
    By Florin in forum Stepper Motors / Drives
    Last Post: 06-25-2009, 02:21 AM
  4. sanyo denki p5 servos
    By vertcnc in forum Servo Motors / Drives
    Last Post: 09-04-2006, 11:26 PM
  5. Step-Syn from Sanyo Denki
    By tecno in forum CNC Machine Related Electronics
    Last Post: 11-10-2003, 01:06 AM
