This is a summery of my entire build 50"x50" KRMx02. My main build log is hosted on kronosrobotics forums. This is only showing my main text entries and ideas/thoughts i went through during the build. I will also show pictures/videos. I omitted the metric sizes i used myself but if anyone interested they can get it from the main build log or just request it here and i will add it.
To make things faster, some of the text here will be exact copy/paste from text i wrote on the main build log
I am building this CNC in Dubai.
First bump on the road is that 80/20 material with that huge weight is going to cost 140% more than the cost of the material itself to ship here. or around 80% of the cost of the material if shipped by sea as its not full container load but part of a container and for that distance that is at least $900 for sea freight and on top of that, it needs a whole month to get here! 80/20 sells Pre-Cut to length & Tapped AL extrusion kit on eBay. This cost $1,242 + Shipping
CRP (CNC Router Parts) kit is not heavy so that is ordered and is on the way. So the decision was either i get the profiles from the US with its 'Inch" spacing T-Slots and stick to the design with huge added cost. Or get an "mm" spacing T-Slots and slightly adjust the design and so some saving!
With the high cost of shipping that far out, i managed to get the profiles from a major industrial factory in China for 60% of the price in the US and much cheaper shipping.
The material is of equal mass/strength as 80/20 so i am not worried about the quality but of course this needs to be verified once i get the material here next week.
The Metric AL extrusion from China is around $750 with longer lengths as well (2 meters each)
I did put a lot of hours studying the design and i already figured out most of the small changes in the design lengths to accommodate for slightly different Profile data. The difference is that 80/20 extrusion has 1.5" spacing (center to centre) between the Slots. Metric Profiles uses 40 mm difference. Plus height/width are different as well. I am using 80x160 (mm) in place of 3060 and 80x80 (mm) in place of 3030. I probably will keep the 1530 section (Z axis) as all CRP kit requires the 1 1/2" T-Slot spacing.
