588,699 active members*
7,247 visitors online*
Results 1 to 13 of 13
    Nov 2007
    5
    5136 FSSB alarm on fanuc Oi mate
    Hello there....
    I have a v-20 leadwekk milling machine.
    It has a Fanuc SVPM A06B-6134-H302.
    My problem is the Alarm 368 on x,y and z axes serial data error
    alarm 369 data transfer alarm, 364 soft phase alarm, 5136 FSSB low amp alarm.
    Any can help me please...what should be the possible causes of this consecutive alarms?
    Thanks.
    Jan 2007
    48
    Check yhe fiber optical cable
    Jan 2006
    121
    What is the alarm status on the SVPM A06B-6134-H302 ?
    Nov 2007
    5
    I have the optical link replaced but problem remains.
    Nov 2007
    5
    Quote Originally Posted by fanuservicetech View Post
    THERE ARE NO ANY ALARMS/STATUS ON THE SVPM AS WELL AS THE FANUC CONTROL.ONLY "--" BOTH STATUS 1 AND STATUS 2 ALSO WITH THE NC.
    Jan 2006
    121
    Alarm 368 and 369 are indicating problem with your pulse coder feedback. BUT you are getting alarms on all axes and it is not possible that you have problem with pulse coder feedback on all 3 axis. It does sounds like you have the SVPM problem. Have you talked to Fanuc Philippines for technical support? Here's something I find on internet on this drive unit but does not have troubleshooting info. Goodluck.
    http://www.astor.com.pl/www/Download...65322_EN01.pdf
    Nov 2007
    5
    THANKS...I THOUGHT IT TOO.BUT SOMETIMES IT WORKS.ALARMS DISAPPEAR BUT IT RETURNS AGAIN AS THE MACHINE IS TURNED OFF OR ENCOUNTER POWER FAILURES.I HAVE TRIED THE SVPM OPENNED AND CLEANED BUT IT DOESN'T WORK.EVEN THE NC MODULE.
    Jul 2009
    I have a FRYER TEACH LATHE that had the same 5136 FSSB alarm on it, with nothing showing on the DRIVE its self. The end result was that a hot chip had shorted the encoder wire to ground. On the FANUC A06B 6114 H103 drive a flashing light will show axis
    Mar 2009
    may i know this happen at what status condition?
    Jul 2009
    Mach will fire up with 1536 alarm , The drives will also come on , but not to inable stat. No axis will fuction . If one of the drives shows a flashing (-) un plug that encoder at drive with power on and see if (-) quits flashing. Control wiil still show number of amps wrong . Check that wire and conections. I found a broke wire one time in flex that follows the control gave me a intermit. Prob.
    May 2006
    64
    I have same problem with you.
    It issues from Servo Drive, Control PCB board was broken, I see some IC component was burn.
    I replace 03 drive for this problem with Fanuc OI MB System.
    Goodluck
    May 2007
    8
    5136 FSSB alarm is linked to the PSM unit.
    Check 200 volts going into the unit.
    If the voltage is ok and in then the unit indications should be on.
    Then check the L1 L2 L3 power supply from the mains at the bottom. going into the unit.
    This will come in only when the MCC signal from the PSM unit turns on the contactor.
    This is all to be checked and solved. Good luck.
    Feb 2006
    213
    5136 FSSB problem, Check encoder feed back cable. Same problem I had faced couple of times. It was encoder cable problem.
  1. FSSB 926 Alarm
    By Factory Guy in forum Fanuc
    Last Post: 03-19-2018, 04:26 AM
  2. Mori SH403 5136 alarm
    By JACKOFTRADES in forum Mori Seiki lathes
    Last Post: 10-10-2015, 06:46 AM
  3. Alarm 926 FSSB
    By wanchai101 in forum Fanuc
    Last Post: 01-10-2012, 09:44 AM
  4. Replies: 9
    Last Post: 11-20-2008, 05:27 PM
  5. FANUC 926 FSSB ALARM
    By sting_dot in forum Fanuc
    Last Post: 12-05-2007, 06:47 PM
