Spindle: 5.3hp w/ VFD from HomeShopCNC.com
Drivers: Gecko203V's
Mach3
X: 25mm profile rail from PbcLinear.com, 20pitch rack & pinion(20tooth pinion), geared 3:1 with 5mm HTD timing belt & pulleys, Pair Keling 2880 steppers
Y: 25mm profile rail from PbcLinear.com, 20pitch rack & pinion(20tooth pinion), geared 3:1 with 5mm HTD timing belt & pulleys, Keling 1840 stepper
Z: 30mm profile rail from PbcLinear.com, 5/8" ballscrewKeling 1200 stepper
A& C: 4:1 geared with 5mm HTD timing belt & pulley, Keling640 stepper.
CandCNC MP3000 Dthc with ISS2 spindle speed control for spindle. System will either use a switch or have to change plugs for plasma/router mode.
CAD model is AutoCad2007 solids model and is essentially the same as for the 96x48x22 build, but with a few upgrades/mods. The big change will be the design of the Y carriage to increase stiffness and allow better alignment of the Z-ballscrew.
The gantry tops out about 8 1/2' above the floor & the top of the Y carriage is at about 9 1/2'.
