I found a good deal on E-Bay for a 5C collet chuck, but it requires an adapter plate to fit my spindle. I had a piece of 1/2"steel drop from some old project that was just the right size and it had a flame cut hole in the center almost the perfect diameter. I chucked it up with my outside jaws first and bored the center hole true and to size to fit over my spindle. Then I took it out, changed to the inside jaws and gripped on the center hole and faced one side. I then turned it over and faced the opposite side, turned the OD and turned the shoulder diameter to fit the collet chuck recess. I clamped it to the mill table on top of a piece of 3/4 MDO and did the drilling by hand. I first found center with a center finder, then using the bolt hole function in my DRO I moved the table around by hand to drill the 3 different hole patterns. The center 4 holes with the counter bores secure the plate to the spindle. The next 4 hole pattern fits a 4 jaw chuck that I had and I used a bushing to center it to the spindle bore. The outer 3 hole pattern and the shoulder fit the Collet chuck.
