Here is the fourth iteration for the full machine.
The table's length was extended to 35". Pushing it to 40" as suggested last week was not possible. Therefore, its final dimensions are 35" × 20", and it currently stands at 35" above the ground without feet. Knowing that vibration dampening feet will add about 2.5" and that a typical height for a workbench is 36", we'll try to bring it down by 1.5" (that should not be a problem).
The linear encoders for the X and Y axes have yet to be added. The one for X won't be a problem, but we'll have to be creative for the one on Y. Several options are available for it, but none are as straightforward as what we can do for X and Z.
The saddle (Y axis carriage and rotary table) is very beefy now, and some weight reduction is probably in order, but I wanted to focus on dimensions and clearances first.
The height of the X-axis carriage was increased in order to provide more clearance underneath the rotary table's torque motor's stator for the drag chain that will be used for cables and hoses.
Very curious to read what you think if this latest iteration.
High-res pictures on public drive:
https://drive.google.com/drive/u/3/f...3dQrx?ogsrc=32
