587,999 active members*
3,952 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > 6-axis Horizontal Machining Center for Education
Page 26 of 29 162425262728
Results 501 to 520 of 564
  1. #501
    Jun 2018
    574
    Atc
    Upgrading to the larger HS610 double-sided spindle head has introduced an interesting challenge: the head is much wider, and it will be virtually impossible for it to reach a tool without interfering with adjacent tool holders. We've tried different solutions to work around this problem, but it looks like we will have to move from a basic conveyor to a full-blown automatic tool changer with double arm. Therefore, we've decided to upgrade to the MUL 105:
    http://www.cdsindexers.com/cnc-machi...mul-series.php
    You can watch a video of the system in action there:
    https://www.youtube.com/watch?v=GRw__hiXioE
    Obviously, it will be quite a bit more complex and expensive, but I do not see any way around this. Fortunately, this upgrade will bring three side benefits:
    1. Chip-to-chip tool change will be much, much faster.
    2. The conveyor won't have to be offset from the center's column.
    3. We could eventually design a system for many more tools.
    We hope to get CAD models for the MUL 105 sometime this week. Stay tuned...
  2. #502
    Jun 2018
    574
    Light Lines
    Take a look at this presentation:
    https://docs.google.com/presentation...405ca24a66_0_8
    There, you might notice that we have red lines on the vertical side panels. These colored lines will actually be produced by LED stripes mounted behind translucid plastic t-slot covers. As a result, we will be able to control their color and blinking. In fact, we'll be able to display multiple colors at the same time on different sections of the lines. This will replace the traditional light tower that is typically mounted on the roof of CNC machines.
    Originally, we got the idea from the DATRON M8 CUBE, which does something similar with their gantry.
    "Il faut rendre à César ce qui appartient à César."
    Attached Thumbnails Attached Thumbnails Screen Shot 2018-08-19 at 10.09.57 PM.jpg
  3. #503
    Jun 2010
    4262
    Re: Telescoping Hydraulic Cylinders
    I think we've found a proper way to drive our rising front panels: telescoping air cylinders.
    We will use two cylinders, one on each side of the panel assembly.
    TWO telescoping air cylinders? They will get out of sync and jam. Murphy's Law.
    Cheers
    Roger
  4. #504
    Jun 2018
    574
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Roger,
    I am concerned about that as well, but I wonder if there is a way to sync them up. What would be the alternative?
  5. #505
    Jun 2018
    574
    HSD HS610 Spindle Head
    Here is the HSD HS610 Double-Sided spindle head in all its splendor:
    https://drive.google.com/file/d/11G-...ew?usp=sharing
    More than a meter long... 290kg of Italian high-precision engineering.
    It will cost us $87k, adding about $50k to our bill of material. That is quite steep, but the benefits totally justify the price increase in my opinion. In fact, I was expecting it to be quite a bit more expensive, because it's four times the weight of the HST310, but only just a bit more than twice the price.
    The connector panel on the back side is certainly intimidating...
    High-res pictures on public drive:
    https://drive.google.com/drive/u/3/f...3dQrx?ogsrc=32
  6. #506
    Jun 2018
    574
    New spindle
    More than a meter long... 290kg of Italian high-precision engineering. It will cost us $87k, adding about $50k to our bill of material. That is quite steep, but the benefits totally justify the price increase in my opinion. In fact, I was expecting it to be quite a bit more expensive, because it's four times the weight of the HST310, but only just a bit more than twice the price.
    High-res pictures on public drive: https://drive.google.com/drive/u/3/f...3dQrx?ogsrc=32
  7. #507
    Jun 2018
    574
    New Spindle
    Attached Thumbnails Attached Thumbnails Spindle Perspective.jpg   Spindle Back.jpg
  8. #508
    Jun 2018
    574
    Updated drawings with new spindle head
    It took us two weeks to get the CAD model for the HS610 spindle head, but it was worth the wait...
    Here are the updated drawings with that new spindle head:
    https://docs.google.com/presentation...05ca24a66_0_50
    High-res pictures on the public drive:
  9. #509
    Jul 2018
    4
    Re: 6-axis Horizontal Machining Center for Education
    Ishi, maybe you could use a scissor mechanism like a car's side window has.
    Something like this, but with pneumatic actuator instead of electric motor:
    https://www.google.hu/search?hl=hu&a....0.-I3O_ct9anc
    Anyway, I follow this thread since the beginning, your enthusiasm and vocation is inspiring. Keep up the good work.
  10. #510
    Jun 2010
    4262
    Yes, you can get rough synchronisation using combined hydraulics and pneumatics, but it is messy, and can still drift. I have used it before to get speed control.
    A solution which is probably over 100 years old is to lay the pneumatic cylinder down horizontally and use it to drive two flexible cables, one at each side of the pane. You can get absolutely beautiful flexible SS braided cables these days ... and pulleys on little bearings. Really smooth.
    Cheers
    Roger
  11. #511
    Jun 2018
    574
  12. #512
    Jun 2018
    574
    Here are the latest drawings for the machine's enclosure, to which we've added the HS610 double-sided spindle:
  13. #513
    Jun 2018
    574
    Yesterday, we received the CAD model for the HS610 double-sided spindle. It won't be cheap: $87K. And it's big, really big: 1m long, 290kg heavy. But if we want to match the 3 micron accuracy that we have on our linear axes with a 500mm diameter turntable, we really need the 5 arcsec accuracy on the rotary axes.
  14. #514
    Jun 2018
    574
    Roof Design
    Our current roof design made of two panels won't work: the rear panel will interfere with the ATC.
    The only solution I can think of at this point is to mount the rear panel vertically and have it rotate around the X axis, but this is way too funky...
    This one promises to be a real challenge...
    UPDATE: I think I found a solution. The panel can indeed be mounted vertically, but pointing downward instead of upward (as I was originally envisioning it). This panel would be closed only when loading heavy parts with a crane, which means that we won't have to actuate it whenever the front panel is lowered or raised.
  15. #515
    Jun 2018
    574
    Sorry for all the repeat posts regarding the spindle: yesterday, CNCzone.com was still flaky, and I could not get access to page 43. Somehow, the thread got stuck at page 42, which is kinda cool if you're into geek numerology... Anyway, seems to be back to normal, and regular posting will resume.
  16. #516
    Jun 2018
    574
    Quote Originally Posted by trb100 View Post
    Thanks a lot for the kind words trb100. I will definitely take this as far as I can, solving problems one by one.
    Regarding scissor mechanisms, this could work, but we would have to engineer some complex mechanical components ourselves. Instead, I'd rather buy something off the shelf if at all possible.
  17. #517
    Jun 2018
    574
    Cheers
    Roger
    Roger,
    That could work, but it's mechanically quite complex, and I am concerned about possible maintenance and adjustment issues.
    That being said, I really like the idea of having multiple solutions to solve the problem, because it will ensure that we do not get ourselves stuck in a corner...
    I'm also considering some telescopic linear actuators with servo motors, because these would be much easier to synchronize. But they would likely be much more bulky and expensive...
  18. #518
    Jun 2018
    574
    Learning
    What I love about this project is the variety of technical domains that I have to learn about. In no particular order:
    - Kinematics
    - Physics
    - Mathematics
    - Mechanics
    - Mechatronics
    - Robotics
    - Electrics
    - Electronics
    - Hydraulics
    - Pneumatics
    - Thermodynamics
    - Metallurgy
    - Informatics
    - Ergonomics
    - Economics
    From there, the main lesson that I learned is that when working on a complex project, any change in one area can have ripple effects on many other areas, in indirect an non-linear ways. There is no free lunch, and every decision will be a matter of compromise. I believe this to be true for any kind of engineering project, but I come from a software engineering background, and software engineers are notoriously bad at this, because software (wrongly) appears to be "softer" than other domains, and software changes always look simple at first. But in reality, the same logic applies.
    Therefore, one has to be very clear about the set of parameters that are important for the project, and very open minded about everything else. Otherwise, you quickly end up with an over-constrained problem that cannot be solved. And one should always consider the fact that any changes to the design will be a lot more expensive than they might have seemed at first...
    To make a long story short: I am learning a ton, and this is a ton of fun...
  19. #519
    Jun 2018
    574
    Spindle Head Protection
    We've extended the top part of our machine enclosure 50 mm forward in order to fully protect our spindle head. This will ensure that if our loaded part clears the enclosure's frame, it will clear the spindle head as well, as long as the spindle is moved 90 degrees around its A axis.
    As a side benefit, it will also ensure that our rear roof panel does not collide with our spindle head when the roof panel is lowered.
    Attached Thumbnails Attached Thumbnails Screen Shot 2018-08-21 at 10.44.47 AM.jpg
  20. #520
    Jun 2010
    4262
    A bit of string going over a couple of pulleys - complex?
    Adjustment would be set-and-forget.
    I have done this recently on my hydraulic press to lift the cross-arm, with two lengths of 'string' over pulleys at the top and down on each side. Works dead easy.
    Cheers
    Roger
  1. 6-axis Horizontal Machining Center for Education
    By ishi in forum Uncategorised MetalWorking Machines
    Last Post: 07-08-2018, 02:26 PM
  2. Replies: 0
    Last Post: 08-02-2011, 02:01 PM
  3. Horizontal vs Vertical Machining Center
    By B.Reilly in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2011, 08:09 PM
  4. CNC Machining Center- both Vertical and Horizontal - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:49 PM
  5. Which CNC machining center for education
    By 44-henry in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2009, 05:35 AM
