603,960 active members*
3,449 visitors online*
Results 1 to 5 of 5
    Sep 2009
    12
    6 cycle engine
    Here a a video of my 6 cycle engine I built about 7 or 8 years ago. I put a smaller base under it today and spent some time playing with it.
    [nomedia="http://www.youtube.com/watch?v=o6PJ2jZyoyc"]YouTube - 6-Cycle Hit miss engine[/nomedia]
    Apr 2003
    1873
    Sounds real good, I liked the thumpy sound.
    What is the 6 cycle referring to beyond the normal 4?
    Sep 2009
    12
    It has extra exhaust cycles suppose to be more efficient and run cooler.
    wankle engine
    Yes it is the wankle engine it is a word and not a name.
    The Wankel engine consists of a rotary piston with interior gears that are in a three to two ratio for example the rotor has 30 gear teeth and the stationary gear has 20 teeth. The old Mazda engines had 2X17=34 stationary gear teeth and 3X17=51 interior ring gear teeth. In one revolution of the e-shaft the rotor is held stationary two thirds of a revolution therefore it advances one third.
    The wankle engine is different it's gear ratio is different. It has a 32 tooth stationary gear and a 24 inch spur gear attached to the rotor. In one clockwise revolution of the e-shaft turns the rotor 1/3 revolution counter clock wise. The combustion at top dead center creates energy like a bullet out of a rifle.
    It is a fact of life little known that energy is created by creating an imbalance.
    It is probable that the gear ratio can also be 24 to 40 with double the e-shaft throw.
    Any interest I have plans and the gears.
    May 2005
    56
    I'd love to see this entered in the cncmentor.com build log competition....impressive!
    http://cncmentor.com - open source sharing community and CAD Library
  1. Search drawing from free piston engine ->stelzer engine
    By Enginetuner in forum I.C. Engines
    Last Post: 12-20-2022, 11:13 PM
  2. Heidenhain iTNC 530: Using Cycle 19 and Cycle 8
    By Dan B in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-27-2011, 05:32 PM
  3. sequential cycle rotary engine (SCRE)
    By dr kingston in forum I.C. Engines
    Last Post: 03-22-2007, 10:34 PM
  4. Atkinson cycle engine
    By mark c in forum I.C. Engines
    Last Post: 01-21-2007, 04:50 PM
