587,172 active members*
3,073 visitors online*
Results 1 to 5 of 5
    Mar 2010
    20
    6040Z Help with A axis
    I recently purchased a 6040Z 4 axis router mill. Everything seems to work correctly and have ran several programs verifying everything. But when I use the rotary axis (axis A),using code G1 F10.0 A90.0 the axis seems to act like it is moving 90 inches, instead of 90 degrees. I cant seem to find a setting to change this issue. any help would be greatly apricated. thanks.
    Apr 2004
    5740
    Re: 6040Z Help with A axis
    I'm not sure what program you're using to control that machine, but in Mach3, you'd go to Config/General Logic Configuration and make sure the "A axis is angular" box is checked. Otherwise it will be linear.
    Andrew Werby
    Website
    Mar 2010
    20
    Quote Originally Posted by awerby View Post
    I am using cnc usb software, I’ve looked through the setting couldn’t find any setting like that.
    Mar 2020
    27
    what is the controller brand?
    Mar 2010
    20
    Im not sure of the controller brand, this is what I bought https://www.ebay.com/itm/4-AXIS-CNC-...72.m2749.l2649. I do remember seeing mk1, if that what you are asking?
  1. CNC 6040Z X-Axis crawls, Help?
    By Pgold in forum WoodWorking Topics
    Last Post: 09-27-2019, 12:32 PM
  2. Soon to be 6040z 4 Axis Owner.... Maybe
    By MrHotwire in forum Chinese Machines
    Last Post: 08-31-2019, 02:42 AM
  3. Scotle 6040Z jamming Y-axis
    By erock001 in forum Chinese Machines
    Last Post: 11-06-2017, 03:42 AM
  4. 6040z 4-axis Router Help
    By ArkSeyonet in forum Chinese Machines
    Last Post: 04-20-2015, 02:22 PM
  5. 6040Z+S80 - using the 4th axis
    By MarcusWolschon in forum Chinese Machines
    Last Post: 08-13-2012, 12:12 PM
