587,941 active members*
3,340 visitors online*
Results 1 to 9 of 9
    Dec 2009
    7
    6061 T6 turning/milling job
    I need approximately 100 of the attached part, with some slight variation in the outer circle pattern (80 ea with 16 holes, 20 ea with 14). Max OD of this part is 64mm, thickness of 14.5mm. I will also need 100 associated parts that are slightly larger (74mm max OD). I will also need another 100 pair of similar parts.
    I can provide an IGES file.
    These parts will also need type 3 hard anodizing, and some milling after the ano process.
    Send me a note and I can give details.
    Jan 2008
    449
    If you are going to anodize you should spec USA or European aluminum and require certs, the cheap Chinese crap aluminum people will use is going to have issues.
    You also need to provide tolerances for an accurate quote.
    Dec 2009
    7
    Quote Originally Posted by Dualkit View Post
    I might have done that if I knew what you were talking about. Thanks for the help.
    Jan 2008
    449
    Quote Originally Posted by rkappius View Post
    Chinese aluminum is famous for leaving discoloration and spotting after anodizing. You could send the anodizer 100 parts and 75 would look good and 25 would end up being scrap. By certs I mean certification papers which shows what mill the aluminum comes from.
    Feb 2006
    6
    We wouldn't mind taking a look at your project and quoting your three different parts
    if I have not misread. Would be great to see solid files or prints for the three parts in
    question. We have several great places to source for the anodize and have had great luck with them in the past. To follow up on Dualkits reply, we only use domestic aluminum for our parts and keep copies of our mill certs on file for ourselves and the customer. We like to keep an open line of communication with our customers and
    are always available to talk to you directly if you would prefer. (785) 877-5381
    You can email any files to [email protected], Look forward to hearing from you.
    You can take a look at our shop Miltech Machine, give a look and see what you think.
    Thankyou!
    Feb 2006
    196
    Did you find a source for your project yet? If not, we would be interested in quoting. Please send the data file. What about dimensional tolerance?
    Thanks,
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
    Sep 2011
    I would also like to quote your parts. Please send info to [email protected]
    Dec 2009
    7
    Successfully found a shop
    Thanks for all the responses, but I've found a shop to do this work.
    Jan 2005
    15362
    Dualkit
    That's the anodizer not the material, I find most of the Chinese material to be better than the US manufactured
    Mactec54
  1. Milling 6061 with X3, need help
    By dneisler in forum Benchtop Machines
    Last Post: 05-24-2008, 11:13 PM
  2. aluminium 6061 milling
    By sharathchandar in forum MetalWork Discussion
    Last Post: 04-14-2008, 04:34 AM
  3. Very rough finish when turning 6061-T6 ... why?
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2008, 11:24 PM
  4. Getting best surface finish OD turning 6061 AL?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2007, 04:57 AM
  5. Turning Aluminum 6061-T6
    By Machine1 in forum Hard / High Speed Machining
    Last Post: 09-11-2003, 06:04 PM
